Ideas on compressing front calipers?
Old Nov 26, 2009 | 12:27 PM
  #41
004x41500's Avatar
004x41500
Originally Posted by Sheriff420
my 2000 has dual piston calipers. and they don't stop the truck worth a damn if your star adjusters are a little loose.
for the hub replacement,
a shower with a good penetrating fluid will go a long way.
the socket is 1 11/16".
factory torque was 185 ft-lbs. the new spec is 175 ft-lbs.
a 3 or 4 foot piece of pipe to put on the end of your 3/4" breaker bar will go a long way. a lot of people break 1/2" breaker bars on that nut.
i used a big combination wrench for leverage on the end of a 1/2" drive socket wrench to get the three bolts out of the back of the hub.
and a screwdriver or prybar in the rotor slots resting against the caliper is better than having someone stand on the brakes because then you don't need a helper. so crack the nut before you remove the caliper.
+1 on the penetrating fluid... and +1 on the 3/4" breaker bar...i myself have broken a 1/2" drive ratchet on that thing when breaking it loose. what i did was use the pry bra and stuck it in the axle u-joint.
Old Nov 26, 2009 | 12:36 PM
  #42
Sheriff420's Avatar
Sheriff420
with knocker loose and a 3' pipe on the breaker bar it was quite easy to get both of mine off. i should have sent my girlfriend out there to take them off.
Old Nov 26, 2009 | 12:44 PM
  #43
Gary-L's Avatar
Gary-L
Veteran: Navy
ROTFLMAO! That made me think of this.
[tube]http://www.youtube.com/watch?v=9wO_6wMRS7A[/tube]
Old Nov 26, 2009 | 12:46 PM
  #44
dsertdog56's Avatar
dsertdog56
Originally Posted by aim4squirrels
It might very well not work, it was just a thought for a fitment trial. But pics can be hard to tell without some scale to them.
I think you'll find thats a pretty accurate comparison. I've handled both designs in the parts business for years. They're as different as chivy and Dodge, except that the early calipers fit chivies too.
But if you don't believe me, go to a parts store and measure them.
Old Nov 26, 2009 | 01:38 PM
  #45
Mudshack's Avatar
Mudshack
sweet!!! I am a pictures guy.
Old Nov 26, 2009 | 04:16 PM
  #46
aim4squirrels's Avatar
aim4squirrels
I'm not knocking your knowledge of the parts at all. Just that pics themselves don't always tell the whole story. They look plenty different, but if one were pictured closer than another, it would be hard to know.
Old Nov 26, 2009 | 07:36 PM
  #47
dsertdog56's Avatar
dsertdog56
Hey, its all good.
Sometimes its good to prove it to yourself though, that's how I've had to learn.
So while you're out grabbing those great holiday bargains, stop by a parts store and if they're not covered up, ask to look at the parts.
Old Nov 26, 2009 | 08:36 PM
  #48
aim4squirrels
I don't know if it'll fit with the new flat screen I want seems like there's been a damn fire sale on those things recently.
Old Nov 26, 2009 | 09:04 PM
  #49
Gary-L's Avatar
Gary-L
Veteran: Navy
Hey, its all good.
Squirrel loves to look at parts. (If you catch my drift)
Old Nov 26, 2009 | 09:52 PM
  #50
aim4squirrels
Just your's, baby. kisses!
