Ideas on compressing front calipers?
Old Nov 24, 2009 | 11:26 AM
Mudshack's Avatar
Mudshack
Default Ideas on compressing front calipers?
I have the brakes pads out and about to put the new pads in. I can't get the calipers to compress/retract back into the caliper housing. I have tried the but of a hammer, the but of a hammer while getting hit by a rubber mallet, the handle of the hammer with all of my weight. Nothing gets it to compress. I have the brake fluid cap off, but can not get any compression.
Any suggestions?
Old Nov 24, 2009 | 11:31 AM
big.red.ram's Avatar
big.red.ram
use a C-clamp. put one of ur old pads against the piston and put ur C-Clamp on it then tighten it up. just make sure its goin in straight. if that doesnt work u may have a seized piston or a bad brake hose. let us know if that works
Old Nov 24, 2009 | 11:32 AM
dsertdog56's Avatar
dsertdog56
Any suggestions?
I would release the caliper bleeder instead and use a LARGE C clamp. If the piston doesn't easily retract at that point, it could be sticking, and you need to replace or rebuild the caliper.
Old Nov 24, 2009 | 11:34 AM
big.red.ram
^ +1 on the bleeder forgot to mention that. if there is any junk in the hose or caliper u dont wanna push it back up into the master. it will also make it easier to compress
Mudshack's Avatar
Mudshack
Thanks. I am on it.
Old Nov 24, 2009 | 11:50 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
No. Remove the cap/cover from the master cylinder reservoir. That will allow the fluid to travel back into the reservoir. Then, there is no need to top off, if at all.
Old Nov 24, 2009 | 12:14 PM
big.red.ram
it can be done either way. which ever way he wants to do it will work
Old Nov 24, 2009 | 12:22 PM
dsertdog56's Avatar
dsertdog56
I did that procedure once...
...and ruined a master cyliinder. I suppose it might've been borderline, but it ruined an inner seal. A simple procedure that I tried a different way became a costly and time consuming repair.
Popping the bleeder cleans out the caliper, and any fluid you need to replace is simply new fluid.
Old Nov 24, 2009 | 12:24 PM
big.red.ram
^ right like i said above if there is any crud behind the piston in the caliber it will just push it out of the bleeder instead of pushing it up into the very expensive master cylinder. ya u may have to add some brake fluid but IMO its better to put a couple bucks towards brake fluid than a coupld hundred towards a master cylinder
Old Nov 24, 2009 | 12:25 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
If "popping the bleeder cleans the caliper" then that means your whole braking system is most likely contaminated. Over time, even the braking system should be overhauled with repair or replacement of the MC, wheel cylinder seals, etc. I prefer to refurbish everything and replace the flexible parts.
