Transmission fluid change
Old Dec 3, 2009 | 09:00 PM
PurplDodge's Avatar
PurplDodge
Originally Posted by J415
That TSB is for 94-96 rams. I'd torque it down to 11 foot pounds. Your call though
Yeah, that TSB was introduced in 1996 as a service manual revision. Then it stayed the same for the rest of the model years.
Old Dec 3, 2009 | 09:15 PM
2001Ram's Avatar
2001Ram
Originally Posted by dhvaughan
^ +1 on that. then install a drain plug in the pan.
http://www.pavementsucks.com/tech-article-39.html
^when draining, note that the fluid level is above the rim of the pan. as you loosen the pan and crack the seal, fluid will run out everywhere. so put a BIG catch pan under the transmission. once it starts leaking out, stop and let it drain for awhile. you'll get one or two quarts out at this point. once the flood subsides, then slide the jack under the transmission pan and drop it. hold it nice and steady with all 3 hands as you lower the jack. or else...
Yeah, thanks that is what I meant to say. I belive you are supposed to use ATF+4.
Old Dec 3, 2009 | 09:21 PM
J415's Avatar
J415
Use only +4. Some people use dex/merc with an additive that's suppose to be equivalent to +4 but I've read too many horror stories about that stuff.
Old Dec 3, 2009 | 09:30 PM
PurplDodge's Avatar
PurplDodge
That additive does not exist.
Old Dec 3, 2009 | 11:31 PM
BlueBeast2's Avatar
BlueBeast2
Ok I have a question about this. I added a deeper pan now when I add fluid how much should I put in before I start the truck and check it for being full
Old Dec 3, 2009 | 11:49 PM
Sheriff420's Avatar
Sheriff420
5.5 quarts seems right. how much more does the new pan hold?
when i dropped my pan the other day i put it back on without a gasket and just let the valve body drip into the empty pan for 3 days. it took a little over 8 quarts to fill it back up and that is with an oem pan and no check ball.
Old Dec 4, 2009 | 12:08 AM
halfamil's Avatar
halfamil
If you don't have a torque wrench just use a 1/4 drive rachet and go around it very slow until snug, not tight.Just don't overdo it.As far as fluid goes, I used DEXRON III for 368,000 miles in the factory transmission so I don't think it hurt it any.
Old Dec 4, 2009 | 12:10 AM
J415's Avatar
J415
Originally Posted by sheriff420
...i put it back on without a gasket and just let the valve body drip into the empty pan for 3 days. It took a little over 8 quarts to fill it back up and that is with an oem pan and no check ball.
damn!!!
J415's Avatar
J415
My bad, I meant to say +3.
Old Dec 4, 2009 | 12:35 AM
BlueBeast2's Avatar
BlueBeast2
IIRC it said 2-4 quarts. That pan actually fits the other style tranny as well. I believe on that tranny it adds less then ours. i think it should be 4 added then.
I have the check ball delete and the new cooler.
In that other post about the cooler I believe it was you that told me to watch out. You said you got rid of the stock stuff and had temp issues. Did you do away with the stock cooler and the rad cooler or how did you do it that you had problems?
