Transmission fluid change
Old Dec 3, 2009 | 06:25 PM
spitfireram's Avatar
spitfireram
Default Transmission fluid change
Im doing a transmission fluid change this weekend. Im going to remove the pan and replace the filter and gasket. Any suggestions for doing this smoothly?
Old Dec 3, 2009 | 06:32 PM
2001Ram's Avatar
2001Ram
Get a jack and place it on the pan, loosen all the bolts and lower the jack slowly.
Old Dec 3, 2009 | 06:55 PM
dhvaughan's Avatar
dhvaughan
^ +1 on that. then install a drain plug in the pan.
http://www.pavementsucks.com/tech-article-39.html
^when draining, note that the fluid level is above the rim of the pan. as you loosen the pan and crack the seal, fluid will run out everywhere. so put a BIG catch pan under the transmission. once it starts leaking out, stop and let it drain for awhile. you'll get one or two quarts out at this point. once the flood subsides, then slide the jack under the transmission pan and drop it. hold it nice and steady with all 3 hands as you lower the jack. or else...
Old Dec 3, 2009 | 07:35 PM
PurplDodge's Avatar
PurplDodge
Use ATF+4 and nothing else.
Pan bolt torque is 135 inch pounds.
Whatever you do, DONT ADJUST THE BANDS!!!!!
Old Dec 3, 2009 | 07:46 PM
dhvaughan's Avatar
dhvaughan
135 INCH pounds is only about 11 FOOT pounds, so don't misunderstand and get carried away.
Old Dec 3, 2009 | 08:03 PM
Sheriff420's Avatar
Sheriff420
i thought it was supposed to be 13 foot pounds.
spitfire, do yourself a favor and go to the dealership and get one of their pan gaskets. it is plastic with rubber on either side. a lot of people have trouble with trying to get a regular rubber seal to not leak. i've never had the dealerships gasket leak and you can re-use them four or five times before they need replacing. and don't use cork, cork gaskets really blow.
edit: it is 13 foot pounds. and the filter is 35 inch pounds.
http://www.rm-indy.com/tech.htm
go to that site and a little bit down the page is a link for a service manual (60mb), its the dodge factory service manual for a 2001 ram and it will be a lot more helpful than a haynes manual will ever be.
Old Dec 3, 2009 | 08:05 PM
xray99's Avatar
xray99
Dodge says 13 ft lbs, I think I'd go with that.
http://dodgeram.info/tsb/recalls/Notice690.htm [step #16 at the bottom]
I've done em most of my life by feel and have never had a leak, but if you got a decent torque wrench, use it.
Old Dec 3, 2009 | 08:20 PM
Augiedoggy's Avatar
Augiedoggy
it should be mentioned you cant get all the fluid out by simply dropping the pan...only about 5 quarts will drain...and the dealership gasket is very nice to work with..
Old Dec 3, 2009 | 08:36 PM
J415's Avatar
J415
That TSB is for 94-96 rams. I'd torque it down to 11 foot pounds. Your call though
Old Dec 3, 2009 | 08:39 PM
Augiedoggy's Avatar
Augiedoggy
isnt the pan and gasket the same on all 2nd gen years??.....I think we are splitting hairs here and either would be fine...
