Transmission fluid change
Old Dec 4, 2009 | 03:22 PM
  #31
BlueBeast2's Avatar
BlueBeast2
Originally Posted by CappinHoff
Noob question, what does a deeper pan do besides give you more fluid capacity?
more fluid actually makes cooler fluid temps
Old Dec 4, 2009 | 03:43 PM
  #32
Sheriff420's Avatar
Sheriff420
you might want to ask tactransman on DT since we don't have MonteC any more.
i don't know much about the amount of cooling needed, just that if the style cooler that you already have is the only cooler then it won't be enough. the style you have added to the stock cooler will help some but if you bypass the stock cooler all together then it won't be enough.
Old Dec 4, 2009 | 05:54 PM
  #33
BlueBeast2's Avatar
BlueBeast2
I think I'm gonna pick up the imperial xl hd that advance has. it's like the stocker in style so I think it should be fine. It's only 50 bucks. I have talked to Terry before when I was looking for a new tc.
Old Dec 5, 2009 | 01:30 AM
  #34
BlueBeast2's Avatar
BlueBeast2
heres the stock cooler
Old Feb 8, 2010 | 06:34 PM
  #35
spitfireram's Avatar
spitfireram
I did it....i replaced the pressure sensor and solenoid....it was so easy, just a bit messy
I bought both off ebay for $104 part number 4617210 and 56028196AD
Old Feb 8, 2010 | 07:03 PM
  #36
J415's Avatar
J415
Originally Posted by PurplDodge
Use ATF+4 and nothing else.
Pan bolt torque is 135 inch pounds.
Whatever you do, DONT ADJUST THE BANDS!!!!!
Hey purpl, finish your sentence. "Whatever you do, DONT ADJUST THE BANDS (WITH A HARBOR FREIGHT TORQUE WRENCH)!!!!!"
Old Feb 8, 2010 | 11:29 PM
  #37
2001Ram's Avatar
2001Ram
So, which is the most affordable and best deep transmission pan? I dont want to pay $200 for one.
Old Feb 9, 2010 | 12:18 AM
  #38
J415's Avatar
J415
I would think the deep pan made by Derale.
http://www.thoroughbreddiesel.com/de...pan-cooler.htm
it cost about $100. Not bad when you think about it. It take 3 quarts more fluid.
Old Feb 9, 2010 | 12:59 AM
  #39
iwhitne's Avatar
iwhitne
i'm going to ask again for the thread.. but does the factory tow package include a tranny cooler?
Old Feb 9, 2010 | 01:03 AM
  #40
J415's Avatar
J415
I believe it does. I've seen a lot of stock tranny coolers on rams in the bone yard. Are you talking about the one that goes in front of the radiator.
