My Plenum Kit fix.
Old Dec 8, 2009 | 11:43 AM
BlueBeast2's Avatar
BlueBeast2
As ****ty as them intake bolts are i wouldn't retorque them. I'm staying away from them damn things. I had enough issues with snaping them off trying to put my air gap on the first time.
Old Dec 8, 2009 | 11:53 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Originally Posted by RedRigRon
Is that because of the gaskets breaking in? I will do so in a week.
I got Marvel Mystery Oil in right now, Seafoam in the next fill up. Didn't think about the 91 octane, I will have to do that. Thanks.
I just realized the manual say to torque the idle pulley to 45 ft. lbs. I did so but never got it to click, felt like it was to tight and gonna snap. same goes for the generator mounting brackets at 40 ft. lbs. and the generator @ 30 ft. lbs.
That's why I never use clicker-style torque wrenches. They're a lousy gimmick and need regular calibration checks. Bar style will never do you wrong.
Old Dec 8, 2009 | 12:24 PM
mjackson92rs's Avatar
mjackson92rs
1. About the removal of the alternator and a/c pump, can you just unbolt the bracket they both rest in and take them out as one unit or must you remove the alternator and a/c pump first?
2. How do you clear the ECU to get it to relearn after the fix has been done?
Old Dec 8, 2009 | 12:32 PM
dsertdog56's Avatar
dsertdog56
When I did my plenum, I removed the alternator completely but carefully flipped the A/C and its bracket over and out of the way on the fender.
When you disconnect your battery, you reboot the ECM, so you should be ok.
Old Dec 8, 2009 | 03:05 PM
Ram_Me's Avatar
Ram_Me
On the Hughes instructions for the AirGap, it says you can speed up the learn process by having BOTH battery cables disconnected, then touching them together for a short time. This resets the computer so it can learn the new manifold faster.
Old Dec 8, 2009 | 03:19 PM
95RAM360's Avatar
95RAM360
i took my A/c and alternator off with the bracket, just undo the connectors, and it will all come out, but keep them in the upward position for the A/c will leak oil
BTW the ALT. will have a connector that has 2 very small 7mm nuts, and 2 10 mm, nuts, make sure not to loose those
Old Dec 8, 2009 | 03:40 PM
BlueBeast2's Avatar
BlueBeast2
so will having the battery and pcm disconnected for over a year be enough to clear it out?
Old Dec 8, 2009 | 03:47 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
30 minutes is adequate, a year is pretty much overkill.
Old Dec 8, 2009 | 05:02 PM
dodgeram07's Avatar
dodgeram07
nice job will hopefully getting on mine as soon as i get my other truck running and tags..ect
bluebeast your going to have to kick the spiders out of the computer..lol
Old Dec 8, 2009 | 05:04 PM
dodgeram07's Avatar
dodgeram07
^^^^that beam isnt close to zero,,,,,,, but yes a beam style or bar style good to be very correct
