What size tire is the same size as a 33?
Old Dec 9, 2009 | 12:13 PM
95_318SLT's Avatar
95_318SLT
Yeah dude, you might wanna read that closer before you try to correct me, thats a 285 75 16, not a 285 70 16.
Old Dec 9, 2009 | 07:23 PM
rideordie's Avatar
rideordie
http://www.onlineconversion.com/tire...conversion.htm
That should help some of you
Old Dec 9, 2009 | 08:15 PM
011500Ram's Avatar
011500Ram
My bad, I misread that.
Old Dec 9, 2009 | 08:21 PM
dhvaughan's Avatar
dhvaughan
285/75-16 generally won't rub on stock 4wd suspension. some report rubbing on 2wd.
Old Dec 9, 2009 | 08:34 PM
99DRAM31887's Avatar
99DRAM31887
yea i was thinking that i just wanna get rid of the 33's i have now and get somthing that will be taller and fill my wheel wells up more. So i didnt know if i should go with the 285/75r16 or even go with the 305/70r 16. I also plan on going back to the stock wheels and get rid of these 15 eagle wheels that the P.O put on
Old Dec 9, 2009 | 10:19 PM
olyelr's Avatar
olyelr
Only thing is, most 16" 285's have an aspect ratio of 75, not 70, so they are the same overall diameter. Where did you get the 70 anyway?
To the OP, saying you will not see any rubbing from the 285's is kinda hard to predict, but with it being an inch skinnier (and they same overall diameter), you have a slim chance in my book. It mainly depends on the wheel backspacing.
Old Dec 9, 2009 | 10:23 PM
olyelr's Avatar
olyelr
If you put 285's on the stock wheels, I will personally guarantee no rubbing with your 2 1/2" lift. The rubbing issue mainly begins with offset rims, which are very common with 15"ers. Hell, 285's pretty much fit without any rubbing with stock wheels and no lift.
Old Dec 9, 2009 | 11:51 PM
95_318SLT's Avatar
95_318SLT
I never said anything about the size existing... It may very well not. I was just going off what 011500Ram said... he made an incorrect statement about the size 285 70 16 and I was just correcting him based on the math. Apparently he just misread something so there isn't a need to go into it any further!
Old Dec 10, 2009 | 08:39 AM
olyelr's Avatar
olyelr
Gotchya, I see now.
Yeah, I have never seen a 285/70/16.
Old Dec 10, 2009 | 10:28 AM
011500Ram's Avatar
011500Ram
When I saw 285 I assumed it was 285/75-16. I used to work for Discount tire and that was the most popular plus sized tire we sold.
