What size tire is the same size as a 33?
Old Dec 10, 2009 | 12:04 PM
  #21
olyelr's Avatar
olyelr
Originally Posted by 011500Ram
When I saw 285 I assumed it was 285/75-16. I used to work for Discount tire and that was the most popular plus sized tire we sold.
And you are correct.
What happened though, was in your upper post (#8) you stated that a 305/70/16 was the same diameter as a 285/70/16, which isn't true and he was correcting you. But, it sounds like you meant to type a 75 instead of 70.
Old Dec 10, 2009 | 12:48 PM
  #22
99DRAM31887's Avatar
99DRAM31887
yea i know about the 285's on stock wheels not rubbing but what about a 305/70r16? will those rub probably just a little bit at full lock or probably not being is its on a stock wheel and not these wide 15's. I mean i had to buy a used one because the P.O did a couple of brake-stands before he got rid of it so i bought a used 33 and when they took the tire off the rim i was like JESUS!!!!
Old Dec 10, 2009 | 12:56 PM
  #23
olyelr's Avatar
olyelr
They might rub on the control arms, thats about it.
Old Dec 10, 2009 | 12:58 PM
  #24
99DRAM31887
ok thanks im wanting to get the ones like on bigtmans dodge i mean i wouldn't mind have the offroad 17's like yours but im not 100% set yet on which ones
