got my truck back from having gears put in :)
Old Dec 13, 2009 | 09:22 PM
  #31
Augiedoggy's Avatar
Augiedoggy
Originally Posted by big.red.ram
wat are you running at 60? im running about 1900-2000. i dont think its only goin to go up 100 rpms at 70. that doesnt seem right since we have the same set up
...maybe your tires are not actually 35" around? or your speedo programming was altered?
I know others on the other dodge forum are the ones who told me 2100 rpm at 70 with 35" tires would be 4.56 gears...I dont remeber what its at at 60 but I know the rpms climb slower in od when speeding up ....at 45 im at about 14-1500 rpm.. so...I think 1900 is about right for 60 though cause its about 2000 at 65 for me...
Old Dec 13, 2009 | 09:49 PM
  #32
big.red.ram's Avatar
big.red.ram
ya im about the same at 45
Old Dec 14, 2009 | 06:22 AM
  #33
olyelr's Avatar
olyelr
Originally Posted by 99DRAM31887
ok guys im not trying to hyjack the thread, but how can you tell what gears you have i mean i know mine came out of the factory with 3.55's and i see ya'll talking about ya'lls rpms at certin speeds. Now is that at full throttle or just cruising because i went and test mine out and at 60 my rpms at a hair over 1500 and i have those 33's on there.
This is a good chart to start from, but remember it does not factor in added rolling resistance from bigger/wider/heavier tires, as well as more wind resistance from a lifted truck. I always recommend going one ratio lower for this reason.
http://www.4lo.com/calc/geartable.htm
Old Dec 14, 2009 | 04:18 PM
  #34
Augiedoggy's Avatar
Augiedoggy
that is a good chart but it doenst factor in our OD trans. either......which would effect the recommended tire size
