parking brake
Old Dec 11, 2009 | 05:02 PM
360mag45's Avatar
360mag45
Default parking brake
well today i got my truck back from inspection and they said my parking brake is not working so.. FAIL and they told me that its probley the gear in the foot pedel thing (idk wht you call it) that ingages the parking brake. I thinck they are right because i have checked it and it dosn't make the rachet sound. Anyone have any ideas on wht it could be and wht its called. And if its the lever assabley how might you go about takeing it out and replaceing?
Old Dec 11, 2009 | 05:05 PM
OSO's Avatar
OSO
Originally Posted by 360mag45
well today i got my truck back from inspection and they said my parking brake is not working so.. FAIL and they told me that its probley the gear in the foot pedel thing (idk wht you call it) that ingages the parking brake. I thinck they are right because i have checked it and it dosn't make the rachet sound. Anyone have any ideas on wht it could be and wht its called. And if its the lever assabley how might you about takeing it out and replaceing?
Does the brake apply if you hold it down?
If you never use it the ratcheting mechanism might just be rusted up and not allowing it to lock in place.
Old Dec 11, 2009 | 05:07 PM
360mag45's Avatar
360mag45
no the brake dosen't apply at all but i well check to see if its rusty
Old Dec 11, 2009 | 05:13 PM
OSO's Avatar
OSO
no the brake doesn't apply at all but i well check to see if its rusty
Check to see if the cable is still attached or in one piece . Could be disconnected from the foot lever or at the rear or just broke. Im sure its has some rust they all do.
Old Dec 11, 2009 | 05:24 PM
360mag45's Avatar
360mag45
ok the cable was in good shape connected both places i taped on it with a hammer and sprayed some wd 40 to try and get the rust out and then tryed it agin and it ingaged the brake but on when it was like 3/4 of the way down and did make the ratched sound so im thincking its worrn out
Old Dec 11, 2009 | 05:34 PM
OSO's Avatar
OSO
If it engages your all good hurry and get your inspection before it locks up again
Old Dec 11, 2009 | 05:53 PM
360mag45's Avatar
360mag45
lol shop is closed all weekend
Old Dec 12, 2009 | 12:21 AM
quackaddict's Avatar
quackaddict
good post I am doing a restoration and I have the same issue, if you push the emergency brake in the light on the dash comes on and the lever stays in position but has no effect. everything is connected got bigger projects to do before I worry about was gonna do a search as well and see what i find.
