Old Aug 7, 2015, 02:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension
Print Wikipost
Confused on Power Steering fluid choice
Old Aug 20, 2021 | 09:59 AM
  #31
Durango4.7L's Avatar
Durango4.7L
A lot of bad information here on thread about power steering fluid! It is confusing!!!
Manual clearly states: Use only Mopar ATF+4 power steering fluid! Dodge sells ATF+4 Transmission Fluid and ATF+4 Power Steering fluid.
There is a difference but I'm not sure if it is negligible or not. Power steering fluid has a higher boiling point? but most people use ATF+4 interchangeably. The price for Mopar is $17.++ and Walmart sells other brands ATF+4 for $6.99 and less. I'll buy Walmart.
Old Aug 20, 2021 | 10:15 AM
  #32
Dean2's Avatar
Dean2
there is some incorrect info but there is a lot of really good info too. Mopar has been all over tha map with what to use in their power steering pumps. It varies greatly by year and vehicle. It can even be different depending on accessories. Read your owners manual carefully and do what it says. Do not take the word of someone on the internet who may have owned one or two Mopars and who think that because their vehicle uses a specific fluid all Mopars do too.
As as saving 6 bucks at Walmart, just how much PS fluid do you go through. That is an area where OEM makes sense.
  #33
Durango4.7L
Default ATF+4 power steering fluid
Manual clearly states: Use only Mopar ATF+4 power steering fluid! Dodge sells Mopar ATF+4 Transmission Fluid and ATF+4 Power Steering fluid.There is a difference but I'm not sure if it is negligible or not. Power steering fluid has a higher boiling point? but most people use ATF+4 interchangeably. The price for Mopar is $17.++ quart and Walmart sells other brands such as Valvoline ATF+4 for approx.$6.99 per quart. (I'm no expert, this is my opinion from researching this issue)
Your decision... This issue is confusing! that's why so many questions.
Old Aug 20, 2021 | 12:55 PM
  #34
prior8t2000's Avatar
prior8t2000
Originally Posted by dhvaughan
i would not. instead, buy a quart of power steering fluid and a turkey baster. walmart has a very very nice baster for about $7, but you really don't need a martha stewart style baster if you can find one cheaper. with a bucket handy and engine off, remove the cap from the reservoir and suck out as much fluid as you can from the deepest edge you can reach. refill, start truck, and drive around the block turning the wheel a lot. repeat. that'll pretty much use up your quart of fluid and will be as good as is needed.
removing the line from the reservoir just runs the risk of crossed threads and it only drains the reservoir, not the box. it makes a huge mess. it also might lead you to crank the engine for a super flush and run the pump dry, which is fatal to the pump...
turkey baster is clean and foolproof.
I did this same exact procedure for flushing out my Steering System.. This is same Turkey Basting tool can be found in every WalMart Store... 2 Trumbs Up for the Steering Wheel Flush method... Thank you.
Old Feb 28, 2022 | 09:11 AM
  #35
lucyfan1976's Avatar
lucyfan1976
The 2015 Durango Citadel ( all models) calls for ATF+4 as per the manual. Mine was empty in the reservoir ( looked like it never had fluid in it) but no visible leaks or anything. So I bought Synthetic ATf+4 from Autozone for more than half the price of the $20 the dealer charges for it. Same stuff. I put it in a month ago and no loss of fluid. I am wondering if the system was low from day one ( sucked it in from factory and I never noticed). I usually would do all my regular maintenance myself but I had free oil changes with the dealer. They are suppose to check fluids and clearly they did not. lol
Old Feb 28, 2022 | 12:42 PM
  #36
If it didn't have any fluid in it for more than a few seconds, it would smoke the pump right quick, and you would also need to be Arnold to be able to turn. Probably just really low on fluid, and yes, that IS one of the things they are supposed to check at an oil change.
Also, you really wanna be in the 3rd Gen Durango section.
Old Mar 10, 2022 | 08:30 AM
  #37
lucyfan1976
It definitely had fluid in the system just not in the reservoir. Once I filled to the max ) figuring some would get sucked in after I drove it for a few days the fluid went down to the min. I topped it off and it has been two weeks now and no change in the level at all. So weird. I looked everywhere and not a leak spotted so I am just wondering if it was low from the beginning? Who knows. Ill keep an eye on it. .
