Trans Cooler Line Lower Radiator Fitting
Old Mar 8, 2022 | 05:10 PM
Cubwelder's Avatar
Cubwelder
Default Trans Cooler Line Lower Radiator Fitting
Hey everyone,
I've got a 2000 Ram 2500 5.9 gas truck (my old plow truck). There's this fitting on the radiator (passenger side) that is just a stub for the push connect fitting for the trans cooling lines. Well, that stub is broken and I cannot find a part number. Any ideas on this one?
Pictures attached to show what I mean. It's the lower cooling line. I'm guessing there has to be some generic part that will work for this..
Thanks,
Dan
Old Mar 8, 2022 | 05:40 PM
master tech's Avatar
master tech
Site Moderator & Tech
You need a tool that is used on A/C lines to remove the line. There is little tab that need to be push back in order to remove the line. But if you are looking for the part that come out the radiator. That maybe part of a new line.
Old Mar 9, 2022 | 08:34 PM
95RAM360's Avatar
95RAM360
Check valve delete? Different fitting than my truck
Old Mar 9, 2022 | 09:41 PM
Do they come on the new radiator??? (my guess would be "no"...) Looks pretty crusty there. Bet that's gonna be fun to get out without trashing something.
Old Mar 10, 2022 | 10:58 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
If you look farther back down the line where it has a big nut is where my check valve was.
Old Mar 10, 2022 | 11:57 AM
AtomicDog's Avatar
AtomicDog
Just an FYI, since you're dealing with the transmission cooling line, here is the procedure to bypass the check valve in the line - https://dodgeforum.com/forum/2nd-gen...46rh-46re.html
