Gas Gauge stuck
Old Dec 13, 2009 | 09:11 PM
95RAM360's Avatar
95RAM360
im just gunna drop the tank...its easy to do and ive done it many times to Rams...but where exacally is it? i havent looked at my Haynes manual or searched it yet cuz im not doing it now. and whats the exact part...Fuel Gauge Sensor?
and will my gas light still work even though its reading full? or are they on the same sensor?
Old Dec 13, 2009 | 10:43 PM
Ram_Me's Avatar
Ram_Me
I am really not sure exactly where it is inside the tank. I would think it would be easy to spot once you're in there. I don't think the light would come on if the sensor reads full. I doubt they would put in a second sensor just for the light, since the odometer would be the backup for the tank.
Old Dec 13, 2009 | 11:35 PM
Bubba39047's Avatar
Bubba39047
on my white truck the gas guage is messed up to. if i fill it up it goes to full, and stays on full until half the tank is used then starts going down. and now at half a tank, its empty. but if its on "F" then its actually half a tank or more, in the tank. I haven't bothered to fix it i just know to fill her up if it almost at half a tank, cause that is now empty. its a 1997 with the 5.2
Old Dec 13, 2009 | 11:58 PM
Dodge.Ismo's Avatar
Dodge.Ismo
Funny,...my trucks been showing signs of fuel level misreadings too, (I've had this truck now for...6-weeks). While showing 1/4 tank on the guage,..I put in $40 bucks more to get it to 3/4. It fluctuates between 1/4 and 1/2 to 3/4 and back.....previous owner hit a deer on gas tank fill up side, (He banged dent out a bit). So I beleive yes...a big jounce, bounce or bang...can fu*k up your intank equipment.
Old Dec 14, 2009 | 06:12 AM
95RAM360's Avatar
95RAM360
Originally Posted by Dodge.Ismo
It fluctuates between 1/4 and 1/2 to 3/4 and back......
mine did that when i hit the brake it would drop half a quarter a tank, and when i hit the gas it would go 1/4 tank above what it shoulda been then it levels out.
Old Dec 14, 2009 | 12:09 PM
Dodge.Ismo's Avatar
Dodge.Ismo
That's just from the fuel "shloshing" forward, (when you hit the brakes), causing the float to sway up....showing more fuel,.. and then "down"ward when you hit the gas...(reverse effect). Also...I believe the low fuel level "eye" you're talking about... actually operates by the float hitting a certain "low" point (low fuel causes the float to go to bottom of tank), causing the eye.. "sensor" ....actually a connection to be completed..which "sends" a signal to initiate the low fuel light on the trucks instrument panel. Therefore:...In the "Dodge" (Chrysler Corporations), company wisdom,...along with most of the other auto makers,...you need to go and buy a new "sending" unit. BUT,..you really don't (NOT THE WHOLE UNIT THAT GOES INTO THE GAS TANK FROM THE TOP needs to be replaced if money is an issue),....just the "fuel sending" portion,...but sometimes it's more feasible,... since the tank is out anyways ...), to replace the WHOLE thing.
Old Dec 14, 2009 | 06:30 PM
Bubba39047's Avatar
Bubba39047
why caint things be simple.
Old Dec 14, 2009 | 06:54 PM
95RAM360's Avatar
95RAM360
^tell me about it...
im thinkin maybe a bad ground could cause this? it just stopped working out of the blue, all the other gauges work fine.
Old Dec 14, 2009 | 07:16 PM
Ram_Me's Avatar
Ram_Me
Mine is knda finiky too. I'll be sitting at a light (usually the same one), I'll look down at the gauge, and it'll slowly "twitch" on it's way down from about 3/4 full to about 1/4 left. Light turns green, I look in the mirror and I don't see half a tank of gas on the pavement, so I feel fine.
Old Dec 14, 2009 | 07:25 PM
95RAM360's Avatar
95RAM360
just for the hell of it, im going to disconnect the battery and reset it. and see if that makes a difference...probably not, but its easy, and it will make me feel better.
