My Christmas gift
Old Dec 15, 2009 | 10:11 AM
Augiedoggy's Avatar
Augiedoggy
Originally Posted by Sheriff420
you can get a 2.5" suspension lift for 160$, how much did the body lift cost?
i think you need to pay attention to brake lines and wires when installing a body lift since they're attached to the body and the frame/suspension. but i'm not sure.
not to do it right and keep the same performance/ride quality you cant....
Old Dec 15, 2009 | 11:20 AM
Gav1n8's Avatar
Gav1n8
You can get spacers and add a leaf for that price. I have never seen any facts saying that you get better ride quality by paying extra for a kit. My buddys truck rides just fine with spacers and blocks. If your trying to ramp the dang thing, you may want to invest in a kit otherwise kits are jokes.
Old Dec 15, 2009 | 12:05 PM
011500Ram's Avatar
011500Ram
Ahh add-a-leaf. The universal alternative to properly building suspension.
Old Dec 15, 2009 | 12:17 PM
rumble_truck's Avatar
rumble_truck
Originally Posted by Gav1n8
I havent had good experience with the bfg mud terrains or buckshots. Maybe got 10000 miles out of each. The MTZ's I have right now are rolling with 4000 miles and still have the nipples on them. I would just invest a little more and get the mtzs. They also grab in mud ten times better in my experience. Just my 2 cents though.
I looked at them, they didnt look all that agressive, but i will research further when i get home.
also, from your sig, you run 42'' tires, i want.
Old Dec 15, 2009 | 12:40 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Originally Posted by rumble_truck
i honestly like the "road noise", my buddy has a set of tsl superswampers, sounds like a damn train is riding next to you, but i think i might go with the bfg's
I have a set of 33" km2's they are so quite. At 80 they are as loud as my at's.
Old Dec 15, 2009 | 01:01 PM
Sheriff420's Avatar
Sheriff420
there's nothing wrong with spacers and add a leafs.
the only change in the ride on my truck is a little less bounce on speed bumps since i put add a leafs on.
you know, a little more height isn't the only advantage that you get from add a leafs. when you have them on there, the truck won't squat as much when the bed is loaded or when you have a trailer hooked up.
the only disadvantage i could see would be a little less travel in the coil springs compared to longer springs. but if a couple more inches of spring travel is that important to someone then maybe they should be shooting for a 5" lift or bigger instead of a 2.5" lift.
Old Dec 15, 2009 | 02:19 PM
Gav1n8's Avatar
Gav1n8
Theres nothing wrong with add a leaf or blocks imo. All give you what your going for which is bigger height so you can clear larger tires. No one is jumping there truck off a cliff purposely so its stupid to build some bullet proof lift kit when blocks or add a leaf will give you the same result.
Old Dec 15, 2009 | 02:23 PM
Gav1n8's Avatar
Gav1n8
I get compliments all the time on how agressive they look. Problem is they cost like 1800 bucks. There worth it though cuz they should last twice as long. 6 ply too which helps becasue they truck gets drove maybe a 100 miles a week and I need something that lasts. Interstate can get pretty noisy but any 42 inch tire is going to be kinda loud no matter what brand it is.
Old Dec 15, 2009 | 03:16 PM
dakotas ram's Avatar
dakotas ram
i believe that he is a prerunner, so yeah its worth it to be bullet proof
Old Dec 15, 2009 | 03:18 PM
rumble_truck
wanna trade?
The kit comes tomarrow, will install and tell you all how it goes, unless i die in the process. thanks for that link on the walk through, woulda been abit lost without it.
