i think my rings might be blowen
Old Dec 14, 2009 | 04:37 PM
Cant Dodge It RAM IT's Avatar
Default i think my rings might be blowen
my truck has been eating oil. so i did a compression test
2-165
4-157
6-155
8-150
1-130
3-165
5-165
7-155
318- 5.2l with 125k
i also been doing some research and found out it could be the plenum?
replace rings? or what
Old Dec 14, 2009 | 04:44 PM
quackaddict's Avatar
quackaddict
You should do what I did, took this as the perfect opportunity to drop in a 360
In all seriousness the one time I had a truck just burning oil like a mother it was the rings and we could tell because the spark plugs were just caked in oil and it was killing the truck.
I am new to the plenum problem though so I am not 100% sure what the signs are for that. You will have an answer shortly because the plenum is a common problem and most can que you in.
Old Dec 14, 2009 | 05:20 PM
i dont have the money or the time to drop in a 360. and all thats gonna do is add 20hp max and suck up alot more gas
Old Dec 14, 2009 | 05:44 PM
011500Ram's Avatar
011500Ram
10hp*
Definitely not worth the time, money and effort.
Old Dec 14, 2009 | 05:46 PM
wjxavier's Avatar
wjxavier
those numbers are pretty good, except for your #1, but that's still do-able. i wouldn't worry about replacing your rings. dude, seriously, use the search function on the top of the page, and look up plenum. theres about 3194820981309.356 threads about this.
Old Dec 14, 2009 | 05:53 PM
quackaddict
Originally Posted by 011500Ram
10hp*
Stock the 360 has 25 more hp. I got a crate 360 with 0 miles, Harland Sharp 1.7 RR, headers, gasket match, kegger mod in my truck for less than 1K. I have a regular cab 4x4 and want the extra hp and torque so worth the time, money and effort to me.
Old Dec 14, 2009 | 06:29 PM
wjxavier's Avatar
wjxavier
also serves as a better base engine to upgrade.
Old Dec 14, 2009 | 06:42 PM
well i dont have 1k to spend i got like less then 300
Old Dec 14, 2009 | 06:45 PM
95RAM360's Avatar
95RAM360
that compression looks fine...its the plenum gasket eating your oil
Old Dec 14, 2009 | 06:49 PM
seabass202's Avatar
seabass202
I agree. those numbers look good. replace that plenum gasket, do a tune up while it's out and the fuel and oil savings will pay for it in short order
