engine work and pics
Old Dec 16, 2009 | 09:54 PM
lord0fsal3m's Avatar
lord0fsal3m
Default engine work and pics
well im finished with the plenum fix and keggar mod, i also painted up a lot of my engine parts and did a tune up, hypertech 180 t stat, MSD 8mm streetfire plug wires, E3 plugs, mopar performance cap and rotor and all felpro gaskets, i had a few snags with the coolant temp sensor and the front left bolt on the intake manifold, i drilled the bolt out and went to tap it and the tap broke inside the whole so i just hoped that it worked and i havent seen any leaks, i sprayed some starter fluid at it while it was running and it didnt bog or rev so i think it will be alright. anyway here are some pics of the finished product.
Old Dec 16, 2009 | 10:04 PM
011500Ram's Avatar
011500Ram
Looks good. A bit bright for my liking, but clean!
Old Dec 16, 2009 | 10:16 PM
95MaroonMonster's Avatar
95MaroonMonster
looks better than mine
Old Dec 16, 2009 | 10:20 PM
Cheat's Avatar
Cheat
On the Alternator, I thought you couldnt just shoot paint on it because of the wiring inside. Someone told me it would mess with it. It looks like you just shot paint on it with out taking the housing off. Is that true?
Old Dec 16, 2009 | 10:27 PM
lord0fsal3m
i just shot it and its fine
Old Dec 16, 2009 | 11:23 PM
lord0fsal3m
i did cover up the ground and plug connecter before i did it, and i didnt shoot the inside just the outside, the the inside of the coils are still unpainted, the outside of the coils dont move and shouldnt hurt it al all, its still charges my system well.
Old Dec 16, 2009 | 11:27 PM
Gav1n8's Avatar
Gav1n8
Well done sir, very good looking. Digging the red.
Old Dec 17, 2009 | 12:52 AM
dakotas ram's Avatar
dakotas ram
what are you talking about with the intake and the tap?
Old Dec 17, 2009 | 10:16 AM
lord0fsal3m
the front left bolt on the intake manifold broke off inside the head, i tried to soak it in wd40 overnight, i heated it up with an oxy acetylene torch and it wouldnt budge, so i drilled it out and went to tap it (a tap it what cuts threads into metal, not assuming you dont know, but just in case) and the tap broke off inside the hole, and since its meant to cut threads into metal its extremly hard, and would be very difficult to drill that out, so i just didnt put the bolt it, and after 30mi still no leaks in the gaskets
Old Dec 17, 2009 | 10:37 AM
bigtman07's Avatar
bigtman07
What is the Keggar mod? Anyone have a link to a DIY?
