Losing volts when I turn on accessories and all power with plow
Old Dec 25, 2009 | 04:57 AM
  #21
JBs DAK's Avatar
JBs DAK
I run a plow on my '96,..
It's normal for that kind of drop.
It recovers shortly after a movement
with the plow.
Just keep the heater on low, radio off
and, it will be fine... If it bothers you,
up-grade the Alt. to a larger one.
Old Dec 25, 2009 | 11:07 AM
  #22
jakemary's Avatar
jakemary
sounds like a normal drop. I also run a 96 2500 plow truck 9' boss and when i pick up the blade the lights dim for a sec. my kids ride with me and couldnt live with out the radio. and the heat is on. a bigger alt wouldnt hurt.
Old Jan 31, 2010 | 12:17 PM
  #23
mnewbolds's Avatar
mnewbolds
My 95 1500 shows the voltage on the gauge at 16v while driving regardless of what accessories are on. But when I stop at a light it drops below 14v. I had two parts stores run a chraging diagnostic and niether found any problems. But it happens while driving not while idling. Could this be the ECM or the Alternator?
1995 Dodge Ram 1500 4x4 5.2L
Old Jan 31, 2010 | 12:25 PM
  #24
Miami_Son's Avatar
Miami_Son
16V is kind of high, but as long as it doesn't drop below 13V at idle you should be fine.
Old Jan 31, 2010 | 02:11 PM
  #25
mnewbolds's Avatar
mnewbolds
UPDATE--- Tested with voltmeter and it was the dash gauge. On my way to Napa for an aftermarket.
