97 wont start, youtube helps..
Old Dec 25, 2009 | 12:18 AM
koneeleven's Avatar
koneeleven
Default 97 wont start, youtube helps..
http://www.youtube.com/user/koneeleven
So, its the first video there, ignore the other b.s... but theirs is my problem..
just want to hear from a couple people that know there rams. yesterday, it had a Click in bottom of the dash( leftside ) ....i dont know. Sat there for mabey a week. i had something pluged in one of my 12v outlets, charge my battery and thats what i got.....HELP
Old Dec 25, 2009 | 06:27 AM
Sheriff420's Avatar
Sheriff420
the click may have been a fuse popping.
on that video it seems like a dead battery to me. the lights dimmed when he turned the key and it is really cold where he is at. cold takes the life right out of a battery if it doesn't have high enough cold cranking amps.
take your battery to a parts store and get it tested to see where you're at. if you need a new one you should get an everstart maxx from walmart, they have 875 CCA and that is plenty for cold starts.
Old Dec 25, 2009 | 07:34 AM
95RAM360's Avatar
95RAM360
Id check all the fuses, and it looks like those terminals dont have a good connection.
Old Dec 25, 2009 | 12:26 PM
koneeleven's Avatar
koneeleven
Never checked fuses..
Tried cleaning the terminals, no diff.
charged the battery the day befor. now that i think about it, it was dead out there for a while. could that of fried it?
Old Dec 26, 2009 | 07:28 AM
Sheriff420's Avatar
Sheriff420
leaving a car battery dead for a while will render it useless. you can wake it up with new acid and a good charge but its just easier to buy a new battery.
when an auto parts store tests batteries, what they do is put a high amp load on them and see how long they take to recover. too long, or if they don't recover (come back to 12v) then the battery is bad.
Old Dec 26, 2009 | 10:23 AM
EndIsNear's Avatar
EndIsNear
Mine did the same exact thing and it was the ignition switch. Lights dimmed as if it was going to start, but the starter wouldn't even turn over. Just made a click when it was engaged in the starting position. I believe you need a new key cylinder or ignition switch. I could gear up and down really fast and throw it in neutral and it would start, but I'm not sure how you could do that with a standard. Anyways, the switch isn't hard to install, just costs a bit....
Old Dec 26, 2009 | 11:02 AM
koneeleven's Avatar
koneeleven
Thats what i didnt want to hear! should i look for a new switch now, or get more thoughts?
Old Dec 26, 2009 | 11:19 AM
EndIsNear's Avatar
EndIsNear
It's up to you. I replaced my starter, Checked the battery, Traced all my wiring, and that was really my last solution. It's not necessarily out of budget for a new switch. Just about $130 or so. I would continue to let others chime in and give their thoughts and try tracing your wiring again just to make sure before you purchase one. Got mine from NAPA. You might be able to find one cheaper. And youll need a tamper-proof TORX head set. It's just like a torx head, just has a small hole in the middle. Youll see what I mean when you look at it.
Old Dec 26, 2009 | 07:34 PM
RedRigRon's Avatar
RedRigRon
Hmmm... same exact thing happen to my Land Cruiser awhile back.
Give the starter a hard whack with a hammer a few times. Then try to start. No joke!, If I am wrong then you wasted no $ trying. If this starts it, then you need a new starter.
Just my two cents.
Old Dec 26, 2009 | 08:15 PM
Cheat's Avatar
Cheat
Just my two cents.
No, No, No, Ive done this before, It brakes the magnets inside it will work once. Thats it, It will totally fry it, But ive heard there are contacts you can replace instead of replacing the whole starter. And could you try to hot wire it? Im not going very far into this but you could atleast try. And the whole starter thing come from a shop thats been rebuilding starters and alternators for 20+ years.
