Gauges
Old Dec 25, 2009 | 01:34 AM
Cheat's Avatar
Cheat
Default Gauges
I would like to add some guages to my 1997 dodge ram 5.9L 4x4 ext. cab, One of the 3 im going to want to add is fuel pressure, How would I go about attaching the sending unit to the fuel line?
I would be using glow shift guages.
Thanks,
Cheat.
Old Dec 25, 2009 | 02:01 AM
PurplDodge's Avatar
PurplDodge
You could put it on the test port on the rail.
Old Dec 25, 2009 | 02:06 AM
Cheat's Avatar
Cheat
Test port?
Could you tell me where its located? Like in the back? Where?
Old Dec 25, 2009 | 02:13 AM
J415's Avatar
J415
97's didn't come with a test port.
Old Dec 25, 2009 | 02:16 AM
Cheat's Avatar
Cheat
*sigh* Thanks, Well any other ideas? besides taping the fuel rails? (last resort)
Old Dec 25, 2009 | 07:35 AM
95RAM360's Avatar
95RAM360
i have a test port on my 95. looks like a valve stem right?
Old Dec 25, 2009 | 10:09 AM
Miami_Son's Avatar
Miami_Son
Try spelling it right (gauges) and you can find a lot of good info in a search.
Old Dec 25, 2009 | 10:26 AM
rideordie's Avatar
rideordie
Two minutes of searching:
"The placement does not matter so long as you can easily see it. On a stock setup, you have only two options and they are:
- At the quick disconnect at the rail or,
- At / off the Schrader Valve."
https://dodgeforum.com/forum/1871397-post35.html
