Dual piston caliper
Old Feb 21, 2010 | 08:18 PM
  #31
lightnin's Avatar
lightnin
Cool deal. Do you think that big of a bore would be a problem? With them on the axle everything clears. The pads look like they are almost twice as thick. Probably alot better than the stock ones but are they better than the 7500 ones? The 7500 are $9 cheaper I think.
Old Feb 21, 2010 | 08:30 PM
  #32
redheadhunter21's Avatar
redheadhunter21
Idk I put on the 7500 ones when I did mine and love them, at the time I was using the part numbers from a chevy and putting on the same ones my brother had on his truck so I could get his ceramic pads
Old Feb 21, 2010 | 09:04 PM
  #33
lightnin's Avatar
lightnin
Thanks for the info. I am hoping to swap the axles into my 01 this weekend. I will post up if the 8800 will or will not work.
Old Mar 26, 2010 | 11:12 PM
  #34
drainman's Avatar
drainman
I am just watching this one to see what happens. But, doesn't the 2500 have a 13 inch rotor where as a 1500 has an 11 inch rotor? Would that make a difference as far as the placement of the caliper vs the rotor? Just curious
Old Mar 26, 2010 | 11:15 PM
  #35
lightnin's Avatar
lightnin
I got them put on. No problems at all. The pad rides in the same place as the half ton calipers did. When you swaped to the bigger calipers did you swap the rattle clip or slide clips as well or use the half ton ones?
Old Mar 27, 2010 | 02:21 AM
  #36
redheadhunter21
Not sure what your talking about and did you notice any play in the brake pedal before it starts braking, like having to push the pedal down farther before the truck starts to slow down thats the only reason I didnt go with the bigger ones and I didnt think I needed them my truck stops on a dime, and hopefully tomarrow I will put in the bigger wheel cylinders
Old Mar 27, 2010 | 03:34 AM
  #37
dodgeram150's Avatar
dodgeram150
so if i have 98 dodge ram 1500 and i want the 2500 caliper i would have to find 98 2500 caliper how does this work im all over the place reading this thread
Old Mar 27, 2010 | 08:29 AM
  #38
lightnin's Avatar
lightnin
I don't notice any play in the pedal. But I have an 01. I think my booster and master cylinder are different since I had dual piston before.
What I was talking about were the metal clips that go on the caliper bracket between the caliper and caliper bracket. I call them anti rattle clips.
Old Mar 27, 2010 | 11:53 AM
  #39
redheadhunter21
Dont have any of those on my truck dont know if that came on the newer trucks and not the older ones or mine just vanished
Old Mar 27, 2010 | 12:20 PM
  #40
lightnin's Avatar
lightnin
I will take a pic of mine. My 01 had them my old fords had them and they have some for the pre 99 ones at the parts store.
