Scary pics of my tranny magnet!!!!!
Old Jan 4, 2010 | 09:58 PM
  #21
halfamil's Avatar
halfamil
You never did say what problems you had with it
Old Jan 4, 2010 | 10:06 PM
  #22
fatchance82's Avatar
fatchance82
oh yeah. well it wasnt shifting into gears, and there was a loud buzzing noise coming from tranny. i thought my tranny was mush. still my turn out to be, but for now all is good. just feels like i need abit of band adjusting. which one can u adjust from outside the tranny?
Old Jan 4, 2010 | 10:32 PM
  #23
halfamil's Avatar
halfamil
Reverse is inside I think.
Old Jan 4, 2010 | 10:36 PM
  #24
PurplDodge's Avatar
PurplDodge
Reverse band is adjusted with the pan off. Front band adjuster is on the driver's side near the linkage.
Old Jan 4, 2010 | 10:45 PM
  #25
spazz1968's Avatar
spazz1968
Originally Posted by Miami_Son
Wear increases after 75k. Might want to have your bands adjusted.
the most imp thing u must leaRn about the ram..... Take care of ur tranny. Good luck.
Old Jan 4, 2010 | 10:55 PM
  #26
PurplDodge's Avatar
PurplDodge
You are sopposed to do that on every vehicle. Whether its a 18 horse John Deere lawn tractor or a Ferrari.
Old Jan 5, 2010 | 12:34 AM
  #27
Sheriff420's Avatar
Sheriff420
the problem people have with adjusting their bands is that some people back the adjusting bolt off either too far or not enough because different year rams need a different adjustment.
all years get tightened to 72 inch pounds then backed off between 1 7/8 of a turn and 4 turns, then you tighten the lock nut and you're done.
if the bands are too tight then they'll dig into the drum and eventually break. and you'll have really harsh shifting.
if they're too loose then the shifts will be really mushy and eventually blow the transmission.
if you don't have any shifting issues then it is best to leave the bands alone.
Old Jan 5, 2010 | 06:45 AM
  #28
fatchance82
reverse is kinda rough to shift to. kinda like my truck is saying "oh yeah heres reverse motherfuc]{3r". going to first is a lil less rough, then the rest are good.
Old Jan 5, 2010 | 07:13 AM
  #29
Sheriff420's Avatar
Sheriff420
you mean it clunks/slams when you put it in reverse? if so then that is normal on a transmission with some miles on it, as long as your u joints on the drive shaft are good and the gears don't have too much backlash.
that line was great, it actually made me laugh a little. the way i read it, its like the subbed K is when the park to reverse shift completes.
Old Jan 5, 2010 | 07:30 AM
  #30
fatchance82
yeah i guess its normal and all. but ya think it be good idea to adjust-or have them adjusted? they never been done.
