Oil leaking now :(
Old Jan 5, 2010 | 10:38 PM
  #21
95MaroonMonster's Avatar
95MaroonMonster
Originally Posted by halfamil
Plenum has never been off either.
sorry, i meant the OP
Old Jan 5, 2010 | 10:56 PM
  #22
halfamil's Avatar
halfamil
Only thing I ever did to the oil pan is tighten the bolts a tiny bit several years back when I had a small drip and put an oversize plug in it b/c the very first time the oil was changed,some knucklehead stripped it out.I have never let anyone else touch it since.
Old Jan 7, 2010 | 05:23 PM
  #23
2001Ram's Avatar
2001Ram
Originally Posted by 95MaroonMonster
how much RTV did you use in the corners of your intake when you did the plenum?
Dime size.. About.. I can smell the oil burning really bad, it stinks!
Old Jan 7, 2010 | 07:54 PM
  #24
seabass202's Avatar
seabass202
This is probably related to the recent plenum work, you may have to reseal that intake, sorry...
Old Jan 7, 2010 | 11:25 PM
  #25
J415's Avatar
J415
Originally Posted by 95RAM360
...i switched right over to synthetic and ive had no oil leaks, so i kinda doubt its the syn change that caused it
Just because it hasn't happened to you doesn't mean it doesn't happen at all. You haven't gotten murdered, but yet that still happens hundreds of times a day.
Old Jan 7, 2010 | 11:33 PM
  #26
95MaroonMonster
wow, that's alot of RTV, i just filled the corners up & then some and let it sit overnight before firing it...no leaks, as of yet
as to why it's burning, check your exhaust manifolds (i spilled a little on mine refilling it today, smoked and stank like a french *****)
