Oil leaking now :(
Old Jan 3, 2010 | 11:46 PM
2001Ram's Avatar
2001Ram
Default Oil leaking now :(
Noticed this morning there was a couple of spots of oil on the ground. Looks like the front and back of engine. This is about 1 week after the plenum fix. When I put the intake back on i was sure to put RTV on all the corners, ect. Also, maybe this has something to do with it. Its been in the 60's and 70's here, and today it was about 40. Could the temp change cause an oil leak. There is alot of "No Oil Leak" at the auto parts store, but will it help or is it snakeoil? I am running Full Synthetic Mobil 1 10W-30, should I try Dino oil or a thicker oil? This really bothers me..
Old Jan 4, 2010 | 12:38 AM
Cheat's Avatar
Cheat
Why dont you find a place to pull it in or just dress heavily (be glad your not in ky its like 9 Deg. Outside) And find out where its comming from exactly. Theres no way to know what might fix it if you havn't seen whats leaking.
Old Jan 4, 2010 | 12:43 AM
dakotas ram's Avatar
dakotas ram
prob from cleaning out your sludge
Old Jan 4, 2010 | 12:47 AM
2001Ram's Avatar
2001Ram
The Diesel, I know. It really sucks. I will get some degreaser, clean everything off really well, and then try to find the leak I guess, right?
Would RESTORE engine additive work?
Old Jan 4, 2010 | 01:04 AM
dakotas ram
personally, i wouldnt put any stop stuff in it......RESTORE isnt made for that, its supposed to be pretty good for its purpose tho
Old Jan 4, 2010 | 01:33 AM
2001Ram's Avatar
2001Ram
Anything else I should do besides cleaning and waiting? Should I use synthetic oil in a pushrod engine?
Old Jan 4, 2010 | 01:38 AM
J415's Avatar
J415
As far as the oil leaks you have, my money's on the Synthetic. It's great at wicking dirt away. Is the oil leak on the lower part of the engine? My first guess is that you need to replace your rear main seal and timing cover seal.
Old Jan 4, 2010 | 06:18 AM
95RAM360's Avatar
95RAM360
throw a quart of Lucus Oil Stabilizer in and see what happens (so you dont have to re-do the oil change) this will make it thicker
Old Jan 4, 2010 | 11:26 AM
2001Ram's Avatar
2001Ram
Might try the lucas... I have been running synthetic for over 15K miles now. See, there is some oil, that drips from the rear main seal and timing cover areas, but I am pretty sure its coming from the upper engine, the whole thing is wet. Yet, I am still full of oil.
Old Jan 4, 2010 | 01:02 PM
J415's Avatar
J415
If it's also coming from the top, then it's probably your valve covers also...all it takes is a little oil to make a big mess. I personally wouldn't touch Lucas Oil stabilizer. It's just a band aid that hides your problem. Deal with the issue at hand and fix it for good.
