Trying to install A steering stabilizer
My old steering stabilizer is shot and i got a new rough country one. Im in the process of taking the old one out got the frame side out but im guessing that the other side is either rusted pretty damn good or pressd in there. Is there anyway of getting it out with out an air hammer.
It is not threaded in, I just did my stabs the other day after I removed the nut I used a tie rod fork, beat the fork on then hit the end where the nut was and it flew off.
Trending Topics
i know autozone rents 2 and 3 jaw pullers. that might work.
pickle forks are not expensive, probably less that 10 bucks.
http://www.northerntool.com/webapp/w...1609_200311609
http://www.harborfreight.com/cpi/cta...emnumber=38649
When I bent mine, I had to take it off right there where I was because I couldn't turn right.... I had a hell of a time with it too, but I ended up unbolting those u-bolts and taking the bracket off the tie rod with the shock still attached. Then, vise+hammer and it came apart. can't remember if it needed heat or not though
