noob air intake question
Old Jan 11, 2010 | 09:17 PM
fatchance82's Avatar
fatchance82
Default noob air intake question
can anyone tell me what this hose is called
and, on a CAI, where would it go?
Old Jan 11, 2010 | 09:30 PM
Miami_Son's Avatar
Miami_Son
That's usually the PCV line. Most CAIs have a fitting for it or include a nipple so you can drill a hole and mount it to the intake tract.
Old Jan 11, 2010 | 09:32 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Umm, thats the crank case breather hose. The PCV goes to the intake manifold. fatchance82 HOW about filling out your profile or sig ? So people know at least what the hell year your truck is!!!!!!!!!!!!!!
Old Jan 11, 2010 | 09:35 PM
Miami_Son's Avatar
Miami_Son
PCV valve=Positive Crankcase Ventilation valve, aka what the crankcase breather hose attaches to.
Silver_Dodge's Avatar
Silver_Dodge
+1. Crankcase breather hose. It allows gas pressure buildup in the head to escape out and be reintroduced back into the intake to be reused. It's an emissions thing mostly.
Old Jan 11, 2010 | 10:01 PM
fatchance82
so its a emission thing. what if i didnt use it, cap it off? let it hang? or just go ahead and use it?
Old Jan 11, 2010 | 10:05 PM
95MaroonMonster's Avatar
95MaroonMonster
i put a standalone breather in its place, b/c my 14x3, it ain't gonna hurt it to have it undone, only difference is the oil vapor is vented to the atmosphere instead of your engine = your air cleaner stays...well...cleaner longer
Old Jan 11, 2010 | 10:15 PM
Silver_Dodge
Yes, but on our engines, the PCV routes directly into the side of the intake manifold, not to the air cleaner assembly. It is just a simple crankcase breather (non PCV) that goes to the air cleaner assembly. Our trucks only have one PCV.
What's your V10 got?
Old Jan 11, 2010 | 10:34 PM
Miami_Son's Avatar
Miami_Son
Good question, I'll have to check. My K&N CAI came with a nipple for the hose, but I never looked to see where the other end went.
FYI, in states that have smog inspections (like mine) venting the crankcase vapors to the atmosphere will cause you to fail the visual inspection and is illegal. Open air cleaner elements (like a 14X3) directly mounted to the throttle body are also illegal here because of evaporative emissions. The entire system has to be closed.
Old Jan 11, 2010 | 11:17 PM
PurplDodge's Avatar
PurplDodge
Keep it on.
