Right rear wheel will not budge
Woke up this morning to drive to work, and my right rear wheel will not budge. The left rear wheel will spin like crazy and throw rubber under power. The truck is a 94 2500 and is only 2WD. A quick look in my library's Chiltons book suggests the following brake related issues may be related to a single wheel locking up:
-Parking brake cables incorrectly adjusted or siezed
-Rear brake shoe return springs weak or broken
-Automatic adjusters malfunctioning
-Wheel cylinder piston sticking or siezed
These all seem sensible. I'm also considering the possibility of an axle related problem, but the book doesn't have any troubleshooting guides that relate to a problem of this type.
Has anyone else had this problem, or know of any other possible reasons why the wheel would be behaving this way? Quick fixes (if possible) would be appreciated as well.
i havent got to the rear brakes yet on my truck. im pretty sure it has drums in the rear. are they hydraulically operated or mechanical? if they are hydraulic, they should have a bleeder right? if they do you can break it loose and maybe it will releave any pressure on it if it is a seized piston or something. im just guessing. i havent even looked at my rear brakes yet.
Well, I'm hearing a lot of advocates for the freezing theory, and we've certainly had a lot of ice in Nebraska the last few weeks. I had the parking brake set, so its highly probably that its been frozen in place. Sadly, I don't have the one tool necessary to look inside my drums (you have to remove the axle bearing on the 2500). I can't even find an appropriate rental from Advance or Autozone.
Maybe I'll just buy a torch...
Trending Topics
