It's alive!!!
Old Jan 15, 2010 | 06:25 PM
redheadhunter21's Avatar
redheadhunter21
Good job and have you taken it for a test drive yet
Old Jan 15, 2010 | 06:40 PM
BlueBeast2's Avatar
BlueBeast2
No test drive yet. Gonna change the oil, throw the tune on, finish the little bit of wiring I have left first. Hopefully tomorrow I can take a spin around at least the parking lot behind my house.
Old Jan 15, 2010 | 07:56 PM
wake's Avatar
wake
congrats man
Old Jan 15, 2010 | 08:02 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Its about freaking time.
Old Jan 15, 2010 | 08:03 PM
Capt. Obvious's Avatar
Capt. Obvious
keep posted vids man. would love to see more. very jealous!!
Old Jan 15, 2010 | 09:20 PM
95MaroonMonster's Avatar
95MaroonMonster
congrats on having a running motor again, i musta missed it, what prompted the rebuild??
anywho, you had to let a huge sigh of relief when it fired, i sure as hell did when i put the intake back on and hooked everything up, i was amazed at how quickly it started, i cycled the key a few times to fill the rails and build pressure, hit the starter and it fired right off
Old Jan 16, 2010 | 12:23 AM
BlueBeast2's Avatar
BlueBeast2
Capt. I will
Maroon: It had a misfire. I was gonna yank the heads off and replace them and do the hughes plenum pan kit and be done with it. A certain member on here (pcfixer) kept saying "your down that far do a cam". I kept saying no till I was actually down that far and seen how close I was to the cam so I decided to do it. When we pulled the cam out a couple of the cam bearings had wear. Also my pistons had knicks in the top of them and lumps of metal on top. No idea what happened to them, I decided for sure after seeing the cam bearings that I was gonna pull it and replace all the bearings. Wanted to be on the safe side. When I took it to the machine shop he informed me that a couple of my bores were weird sizes and it needed bored out. Him having my engine for over a year allowed me to go a little crazy and spend more money on other parts. Which is why I have the air gap and tc. i'm pissed that it took so long but in a way happy cause I was able to mod it more.
Now comes rebuilding my GT's motor
Old Jan 16, 2010 | 12:39 AM
pcfixerpro's Avatar
pcfixerpro
What? shoulda had that block to him at least 6 months ago, that way it is ready when your ready lol.
So whats the plan now to get your timing & fuel sync 100% correct?
Old Jan 16, 2010 | 01:20 AM
BlueBeast2's Avatar
BlueBeast2
my luck he would finish that in a couple days.
Gonna throw the tune on and see if the timing needs adjusted anymore. Fuel sync ain't a major issue right now. Maybe I'll have Troy check it when it goes for inspection
Old Jan 16, 2010 | 06:58 AM
95RAM360's Avatar
95RAM360
which heads did you use? or did you re-use the old heads?
