Blinker electrical problem. Need a little help
Old Jan 17, 2010 | 09:21 AM
  #21
BlueBeast2's Avatar
BlueBeast2
Sorry link ain't posting right from my phone
Old Jan 31, 2010 | 12:26 AM
  #22
uli2000's Avatar
uli2000
Originally Posted by 95RAM360
try this first...
i had the same problem except i had some added problems and it all turned out to be a ground wire at the rear of the truck,
What were the added problems you had? In the space of a couple of hours tonight, I lost turn signals, insturment panel lighting, and now tail lights. Fuses are all good, where should I look for the faulty ground wire?
Old Feb 27, 2010 | 10:48 AM
  #23
cummins24421's Avatar
cummins24421
I replaced the switch with an aftermarket one from advance auto. its very shiny and pretty, but the problem persists. I narrowed it down to only right turns, and its not immediate, it will work for about 5 mins before blowing. I'll try tracing the harness from the right tail lights, but with the utility body, i doubt it's the same wiring as the stock truck. And when it was the ground wire on the left tail lights, it blew the fuse, not the flasher. Kinda gettin to the end of my rope with this thing though, so i'll try about anything atm.
Old Feb 27, 2010 | 02:16 PM
  #24
zman17's Avatar
zman17
Retired Moderator - RIP
You are right about the wiring with the utility body. That is where the problem lies. Connections were changed, grounds were probably moved and are now broke or not making contact. You simply have to trace the wires from beginning to end. No way around it.
Old Mar 6, 2010 | 10:01 PM
  #25
Dcarrone's Avatar
Dcarrone
Default Blinker issues
I seem to be having a similar problem with my 94 Ram 1500 4x4. I have replaced the brake light switch, headlight switch and today the turn/wiper/hazard switch. Is the multifunction switch one that I am not seeing or is that the one the one that controls the turn signal/wipers/and hazard? As for the ground at the rear of the truck where exactly would I look?
Old Mar 6, 2010 | 10:30 PM
  #26
BlueBeast2's Avatar
BlueBeast2
multi function is the wiper/ turn signal switch
Old Mar 7, 2010 | 04:18 PM
  #27
Dcarrone's Avatar
Dcarrone
Today I checked all the coonection in the rear and there is not crud or corrosion in any of the plugs. Does anyone have an idea on where the body ground or any ground wire would be. Also I have a remote started that the previous owner had installed. Do you think that could be causing this wierd lighting issue?
Old Mar 7, 2010 | 04:29 PM
  #28
plott hound's Avatar
plott hound
i had a similar problem with my '96 ram 1500.damn signals and a bunch of other electrical problems.turned out to be a day time running light relay in the trailer wiring harness.my old retired mechanic bud new exactly what the problem was.we cut that sucker out of the eqaution and all problems were solved.
