Replacing wheel bearing............
Old Jan 21, 2010 | 08:50 PM
  #101
yakkier's Avatar
yakkier
Im a cable guy, we work weird hours. But i love having a broadband card and a power inverter in my fleet GMC. just plug my laptop in and type away while im waiting for my next customer to get home
Old Jan 21, 2010 | 08:52 PM
  #102
halfamil's Avatar
halfamil
Way to go 95, now, the next time you repair something in that area, it won't take long at all, now that you've done it!!!
Old Jan 21, 2010 | 08:56 PM
  #103
95RAM360's Avatar
95RAM360
i know, and i cleaned/antisiezed everything, so i shouldnt have a problem when i do my seals when it gets warmer.
on a good note i didnt damage my seal...but my drivers side is bad, which means the pass. side axle has to come out, and then its probably going to get damaged, so ill d them both when the time comes. my drivers side is bad, and ive been through many water/mud pits, and the fluid isnt contamnated/low...so im not to worried about it right now
Old Jan 21, 2010 | 09:09 PM
  #104
halfamil's Avatar
halfamil
You'd prolly have to go thru some deep water, and get stuck for several minutes to get water in there. Depending on how bad the seal is..... I don't go thru anything, more than an inch, or three, unless it's an emergency.
Old Jan 21, 2010 | 11:02 PM
  #105
CSXfan's Avatar
CSXfan
All this talk about wheel bearings got me thinking about my own truck. I replaced the drivers side in August but the passenger side seemed solid then. I checked it last night and sure enough, there's about 1/2" of play in it. At least I'll know what I'm doing this time
Old Jan 22, 2010 | 06:54 AM
  #106
95RAM360's Avatar
95RAM360
was your drivers side reverse threaded for the hub bolt?
Old Jan 22, 2010 | 10:26 AM
  #107
Sheriff420's Avatar
Sheriff420
when i changed my driver u joint i pulled the hub and axle out at the same time because i had a brain fart and didn't think to tap the axle to separate it from the hub. so the axle dragged pretty hard on the seal. it took a few days for it to start leaking.
you can get those seals changed out in half a day if you devote a whole day to it and don't just do a little bit at a time over a few days.
Old Jan 22, 2010 | 10:36 AM
  #108
95RAM360's Avatar
95RAM360
im just worried about taking out the diff....thats whats really making me postpone it.
Old Jan 22, 2010 | 11:14 AM
  #109
CSXfan's Avatar
CSXfan
Nope, it was the regular right handed thread. The passenger side should be the same way right?
Old Jan 22, 2010 | 12:03 PM
  #110
95RAM360's Avatar
95RAM360
yes
According to haynes manual it says this
"On Some Models the DRIVERS Side wheel hub nut will be reverse threaded (clockwise)"
