Replacing wheel bearing............
Old Jan 19, 2010 | 08:26 AM
  #31
Relex's Avatar
Relex
If you are going to tear into your truck and do that wheel bearing and since there is a little play in your u joint, might as well do those too.
My first time doing my wheel bearing took some time even with my friend there telling me what I had to do. To break the axle nut loose it took my friend jumping up and down on a 3ft piece of pipe a few times before it finally broke loose. I replaced the other side a couple months ago and nothing was on there too to tight, it took me about a half hour to do it.
Old Jan 19, 2010 | 08:42 AM
  #32
95RAM360's Avatar
95RAM360
well i went to the car wash last night (since its been 40-50 degrees out latly here in MA) and cleaned all the salt and everything, got home and soaked half a can of wd-40 on the whole back of the assembly. and i just got back from soaking it again. i cant start till around 3:30 or so tonight due to location on wheres its being done. hopefully this will be easy. i know how to do it, thats not the problem, the problem is not being able to break some of the bolts loose
Old Jan 19, 2010 | 08:54 AM
  #33
Sheriff420's Avatar
Sheriff420
wd-40 is also a lubricant. if you can't get the crc knock'er loose, crc freezeoff, or cyclo breakaway then you should at least use liquid wrench. lowes carries liquid wrench and so do the parts stores.
Old Jan 19, 2010 | 10:47 AM
  #34
95RAM360's Avatar
95RAM360
i saw crc freezeoff....i need to get a socket for the hub bolt (didnt relize i didnt have one) so ill grab some crc freezeoff when i go in a little bit.
Old Jan 19, 2010 | 05:26 PM
  #35
Maxx_Magnum's Avatar
Maxx_Magnum
I had a little play in my pass U joint also, and I figured may as well change it while it was all apart. I'd do those seals now too if I were you. just sayin'
Old Jan 19, 2010 | 05:30 PM
  #36
95RAM360's Avatar
95RAM360
i workin against the weather...its pouring out right now...so i cant get into it now...im not doing the seals right now due to the fact that time is also a factor. the way my fiancees and mine scedual go, it makes it so i only have wednesdays to work on things. (when im not working im watching my daughter, and vise versa)
Old Jan 19, 2010 | 06:38 PM
  #37
halfamil's Avatar
halfamil
That's ok, the next time you tear into it, you'll be a seasoned veteran.
Old Jan 19, 2010 | 07:56 PM
  #38
95RAM360's Avatar
95RAM360
thats right lol
the hub nut is 1 11/16 right? cuz thats the one i bought (f'n 30 bucks for one socket)
Old Jan 19, 2010 | 08:03 PM
  #39
halfamil's Avatar
halfamil
Yep!!! It will come in handy the next hub and axle project.
Old Jan 19, 2010 | 08:10 PM
  #40
dhvaughan's Avatar
dhvaughan
^ its also the perfect size for seating rear axle seals in a toyota 4runner and the front inner bearing seal on a ford explorer.
