Old Aug 6, 2015, 12:16 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
Low Beams not working
Old Mar 15, 2020 | 04:45 PM
  #31
Lyla Unperishable's Avatar
Lyla Unperishable
Default Low beams not working
Originally Posted by rocoforce
Hi, I'm new to this site and hope someone can guide me to the right area or is able to help fix my problem. I have a 2001 Ram 2500 5.9L Diesel and it's been a champ up until this fall when I crossed the 100,000 mile marker. At first, my low beam headlights seemed to quit working, then they would be OK.
When they would not work, I could switch over to the high beams and then back, usually it would fix the problem. I looked at a wiring diagram for the multifunction switch and figured it must just be a bad switch. Got a new multifunction switch from AutoZone ($59) and installed it with no problems. The lowbeams seemed to work normal again, but for just a day. Has anyone else had this issue and what was the fix? I've seen where someone said it was a loose cable, but which one? It appears that the controls to the headlights are all "Ground" related. Is it possible to hardwire a new ground with a relay and have the lowbeams on all the time, even when the highbeams are triggered? Thanks, looking forward to many great responses.
i have a 1997 Dodge Ram and the low beam headlights are not working. I’ve already replaced the multi function switch and it worked for a few days then started doing the same thing again where only the brights and the fog lights work. How do I fix this?
