still cant get it running!!
Old Jan 20, 2010 | 12:02 PM
01ramjam's Avatar
01ramjam
Default still cant get it running!!
i replace the plenum gasket and put all back together and had the problem with idle now it is smoking horribly bad (when it runs) its a white color and smells like gas mostly and i have to have the gas all the way down to get it to start then it wont idle. if i keep it reved up for a couple minutes then slowly slowly let the rpm drop it will surge at idle and makes a horrible hissing noise at the throttle body any ideas?
Old Jan 20, 2010 | 12:05 PM
01ramjam's Avatar
01ramjam
also fuel pressure is between 45-50 psi
Old Jan 20, 2010 | 12:07 PM
95RAM360's Avatar
95RAM360
check your TPS, and IAC
as for the smoke...look down into the TB and see if the plenum is leaking again.
what did you use to fix plenum? if you just got a new gasket, you will have the problem again in no time
Old Jan 20, 2010 | 12:52 PM
halfamil's Avatar
halfamil
If it will run long enough to get up to full operating temp. the smoking may stop. The other problem sounds fuel related. Pull the pre-cat o2 sensor out and see what happens. If you can get it driveable for 15-20 miles, you can evaluate the smoking much easier. Then pull some plugs and check those. The smell of raw gasoline out the exhaust says it's not firing correctly.
Old Jan 20, 2010 | 01:58 PM
Capt. Obvious's Avatar
Capt. Obvious
did you do the recommended torque sequence?
Old Jan 20, 2010 | 02:14 PM
01ramjam's Avatar
01ramjam
check down the tb no oil inside the plenum i pulled the 02 senser pre the cat it would not run at all then. were is the tbs and iac located and how do i test?
Old Jan 20, 2010 | 02:33 PM
Capt. Obvious
TPS is on the driverside of the TB, the IAC is on the back (firewall). theres is a thread somewhere on here to ohm out the TPS. as for the IAC.............
Old Jan 20, 2010 | 03:18 PM
yakkier's Avatar
yakkier
Easiest way to find out if either of those two are bad, start the truck unplug the TPS and if you dont see a difference in the idling or throttle response then the sensor is bad, fallow same rule with the IAC. usually if the TPS is bad then when you rev the truck up and let go of the throttle it will die instantly
Old Jan 23, 2010 | 04:23 PM
01ramjam's Avatar
01ramjam
if the gaskets did not seat right on the manifold could it cause this problem?
Old Jan 23, 2010 | 05:29 PM
01ramjam's Avatar
01ramjam
or does anybody know were i could get a wiring diagram for the obd2 port cause i cant get a reader to work on it. they say there is no power coming to it?
