won't start in park (still)
Old Jan 20, 2010 | 10:38 PM
jcann55's Avatar
jcann55
Question won't start in park (still)
hi all
just bought a 98 1500 5.2. Truck wouldn't start in park and it seems I only have 1,2 reverse no drive or over drive. Buddy had a motor trans so I got the trans and replaced it. In the garage after instal all was well(new filter and all) started in park/nutral all was good take her out of garage and now it won't start in park again. Starts in N no problem any help would be great.
Old Jan 20, 2010 | 10:57 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Could be just the neutral safety switch is no good. Did you reuse the TC ? It's possible it's bad.
Old Jan 21, 2010 | 12:31 AM
lblair04's Avatar
lblair04
I had this same problem. My 2nd gear band anchor fell out and wedged itself in the top of the valve body, which kept it from going into Park. I could still start in N. I also lost 2nd gear when it fell out since the SECOND gear band controls 2nd gear haha. It was pretty easy to fix, Im sure there is a thread on it.
Old Jan 21, 2010 | 12:32 AM
jcann55's Avatar
jcann55
sorry I'm new to this but what's the TC?
Old Jan 21, 2010 | 12:35 AM
zman17's Avatar
zman17
Torque Converter
Old Jan 21, 2010 | 12:38 AM
zman17's Avatar
zman17
Have you tried like pulling up on the shift handle and or moving it around while trying to start?
Old Jan 21, 2010 | 12:48 AM
tristatehunter's Avatar
tristatehunter
My Ram does this allot.. not all the time.. but it does happen quite a bit.. Every since I put in the new trans, just figured it was my linkage not adjusted right (indicator needle is off about a half click).. Doesn't bother me in the least.. I have been telling myself to try to fix it for about a year now
Old Jan 21, 2010 | 01:14 AM
jcann55's Avatar
jcann55
TC=converter (thanks)
I used the one that come with the new/used tranny I put in. I tried fiddling with the shifter and wheel still no start in park. I did notice the ignition is sloppy( took the key out and it still moves to the start position) now that I think about it, it was when I turned the keyless ignition to start is when I lost the starting in park
Old Jan 21, 2010 | 01:26 AM
zman17's Avatar
zman17
HMMM, the story deepens, At least we know it can't be the TC. Dive into the ignition switch and the neutral safety.
Old Jan 21, 2010 | 01:35 AM
jcann55's Avatar
jcann55
I will be checking the ign. Thankyou for your input. The N switch, I noticed on the tranny I took out, the switch looks new is this an easy screw in an attach the wire?
