xtreme 4x4 ram
Old Jan 30, 2010 | 10:56 AM
  #41
jmhai's Avatar
jmhai
Looking at 11 inches of powder on the back deck table a hot bowl of cream a wheat w/ toast and Extreme is getting ready to start..... Mills River area got the most around here 13"...
Old Jan 30, 2010 | 11:02 AM
  #42
Sheriff420's Avatar
Sheriff420
we got like an inch, maybe two of the crunchy stuff.
Old Jan 30, 2010 | 11:40 AM
  #43
Augiedoggy's Avatar
Augiedoggy
Originally Posted by Hammer Down
I did my senior project in high school on HHO or "Hydrogen" generators. I built several different designs, experimented and researched a lot. It can improve your gas mileage, but it's a lot easier on a carburated vehicle. In fuel injected vehicles, you have to fool the computer into thinking the truck is running rich, otherwise, once sensing the increased oxygen in the exhaust, the computer will send more fuel into the mixture, negating any gains that you may get.
In a small expperiment, I built a 3' aluminum tube HHO cell with a spiral of stainless steel wire inside. I ran my riding lawn mower idle at mowing rpm with a 1/4 cup of gasoline alone and the same amound with the cell connected to the mower's air cleaner. It ran a considerable amount longer with the cell.
you guys interested in hho cells should google "geet and pantone" some very interesting stuff....especially if you have a gas generator wou want to make like 5 times more efficient on fuel... hho cells are tough to maintain and keep stable...I tried to read up on the patented "stan myers" version that really worked but after watching about 50 you tube videos I wasnt much closer to the key...
Old Jan 30, 2010 | 01:54 PM
  #44
Hammer Down's Avatar
Hammer Down
The hardest thing to crack is a design in which the cell doesn't erode too quickly and the most gas is produced without too much amperage draw. Aluminum corodes too quickly, steel turns to SUPER RUST, and I've even managed to get stainless steel to rust. I did find, however that the best electolyte is vinegar. The acid keeps the metal clean and unlike baking soda, the gas produced is much more pure.
Old Jan 30, 2010 | 01:58 PM
  #45
Silver_Dodge's Avatar
Silver_Dodge
Sorry to go off topic for a second, but Hammer, I just noticed that you have the Dodge off-road rims, but they look powdercoated (or painted??) black. Got any closer pics of those?
Old Jan 30, 2010 | 02:09 PM
  #46
Maxx_Magnum's Avatar
Maxx_Magnum
just watched xtreme 4x4 on the pvr, no ram though ;( it was all about towing
horsepower tv however had a carbed 360 mag with new alum heads, cam, HS rockers, dizzy etc. made just under 400 hp I believe.
Old Jan 30, 2010 | 02:45 PM
  #47
Hammer Down
Here you are.
Also, check this thread out.
https://dodgeforum.com/forum/2nd-gen...-on-black.html
Old Jan 30, 2010 | 03:51 PM
  #48
crazzywolfie's Avatar
crazzywolfie
i think i rember reading somwhere that it is fairly easy to trick the computer into running lean. i also read that hydrogen can also increase HP and make the engine run quieter. i would like to try it and see if i can get 30-40mpg
Old Jan 30, 2010 | 03:56 PM
  #49
Silver_Dodge
With a ROE controller or an Air/Fuel calibrator, you can adjust how rich/lean with just a turn of a ****. I have the Split Second ARC1 A/F calibrator on my truck, and can adjust it for the rich/lean very easily.
http://www.splitsec.com/products/calibrators2.htm
Old Jan 30, 2010 | 04:08 PM
  #50
Hammer Down
EFIE or Electronic Fuel Injection Enhancer is often used with an HHO cell. It sends a constant voltage to the computer to trick it into thinking that the vehicle is running rich.
