ebay headers
Old Aug 14, 2013 | 07:31 AM
  #21
clipper77's Avatar
clipper77
Originally Posted by tresvatos
has anyone had any luck finding a way to tighten that bolt that is on the inside of the pipes nearest the driver/firewall..? I have wasted a half a day fooling with all lengths and several different tools....
Not sure what the layout for your v8 is, but on my v10, removing the fender liners helped a ton with installation.
In addition, I had to lay under the truck and reach up to the header bolts with an open ended wrench in order to tighten all of the fasteners down. Doing it from underneath gave me the correct angle for the wrench to slip onto the nut.
Old Aug 14, 2013 | 11:44 AM
  #22
ChillyPhil's Avatar
ChillyPhil
DO NOT USE THE GASKETS THAT COME WITH THEM HEADERS.
I made my mistake by forgetting to get better gaskets because the ones that come with these are crappy. About 15 miles and I have a leak on the driver side set.
Overall nice headers, not true stainless but they're turning a purplish color. No power gain with them I haven't noticed. Barely noticed a power gain with full tune up, plenum, high flow cat, headers, and my 1.7 hs rockers put on. Even running 93 octane with my sct tuner.
I just noticed it drivers smoother and alittle more power. Not enough power for me though.
Old Aug 14, 2013 | 06:47 PM
  #23
Timbo65h's Avatar
Timbo65h
The ones I got from that particular seller he originally posted are real stainless. It is not a high quality stainless but it is stainless.
Old Aug 14, 2013 | 06:56 PM
  #24
tresvatos's Avatar
tresvatos
Thanks for the input everyone..Still battleing trying to install these two bolts on inside pipes nearest firewall.
Sending back my 2.25" inlet Y pipe for a 2.5" Y pipe too. Will have custom 2.5" Y pipes from collectors to The Y pipe, as we agreed the openings from header collectors are 2.5"
Old Aug 14, 2013 | 06:57 PM
  #25
tresvatos's Avatar
tresvatos
Oh and a side note I forgot, is that my truck has body lift, so don't know if removing fender well liners would actually do anything as far as helping with the header bolt access..
Old Aug 14, 2013 | 08:17 PM
  #26
Timbo65h's Avatar
Timbo65h
As far as the body lift goes I would think with removing the inner fender you would have even more room to work since the gap would be bigger.
Old Aug 14, 2013 | 08:38 PM
  #27
clipper77's Avatar
clipper77
As does mine...
but to each his own.
Old Aug 15, 2013 | 09:37 PM
  #28
tresvatos's Avatar
tresvatos
yes you guys are right. The fender well removal definitely helps, so I stand corrected
Old Aug 20, 2013 | 04:16 AM
  #29
tresvatos's Avatar
tresvatos
Default Can't seem to get the bolts in -Here is a pic.
I have fooled with every tool known to me ( I am an helicopter mechanic in the Military , and I can't seem to find a way to get these two ( inside bolts towards firewall ) started. I have tried shorter bolts, alllen bolts, stub wrench, ratcheting wrench, fingers, joint ext., swivel socket, etc. This is ridiculous for these bolts to be this hard to start. Again this is on a V8 360 gasoline engine.
Again how did anyone who has ever accomplished this with these stainless ebay headers do so...???
Old Aug 20, 2013 | 09:39 AM
  #30
Loosen all the other bolts, pull the header away from the engine some, start the bolts, tighten those to snug FIRST. Tighten the rest. Torque to proper value starting from the bolts in the middle, and working your way out.
