Transmission lifespan?
Old Jan 26, 2010 | 12:24 PM
dodgeboy1979's Avatar
dodgeboy1979
mine went 186000
Old Jan 26, 2010 | 02:42 PM
[roger]'s Avatar
[roger]
I know I got some problems with my Tranny but I dont get any codes.
it shift fine when cold, but then when it hot it wont shift unless you let go of the gas or shift to N and then back to D.
That I dont use my Truck anymore until I get some money to fix it
it saddens me everytime i get home and see her outside gathering dust.
Old Jan 26, 2010 | 08:44 PM
Ron69697's Avatar
Ron69697
damn...im starting to get depressed is this going to happen to my 2005 dodge ram 1500 4.7L? i just got to 45k
Old Jan 26, 2010 | 09:17 PM
wake's Avatar
wake
Originally Posted by Augiedoggy
...I had the 1741 code and same behavior and it was just a bad Governor pressure sensor
same here boss..thats the reason my landlord chose to park the truck and look for a new one..Governor stuck and it made the same noise the OP described and wouldnt pull out of first no matter what we did..let it sit..reset the computer changed the tranny fluid and filter (seal aint holding well but thats my fault) and drove it around and shes been shifting fine ever sense
hope i dont jinx myself here
EDIT..that was at 98-100 thousand..
Old Jan 26, 2010 | 09:21 PM
dsertdog56's Avatar
dsertdog56
Mine was about 120 ish, and I had those codes as well. Replaced the Govenor and ID selenoids and the codes went away. If I'd adjusted the bands I might still be going.
Old Jan 26, 2010 | 11:05 PM
JoeV10's Avatar
JoeV10
I have 152k on the factory one in my 2500. It has towed all of its life. It is still going strong.
Old Jan 26, 2010 | 11:43 PM
J415's Avatar
J415
It's only a matter of time...It'll go pretty soon.
Old Jan 27, 2010 | 08:16 AM
halfamil's Avatar
halfamil
368k here, on the 46RH. 180k on the rebuild. Mostly highway miles.
Old Jan 27, 2010 | 09:08 AM
Kaldir's Avatar
Kaldir
[roger] What color is your transmission fluid? Might need a change.
Old Jan 27, 2010 | 09:41 AM
Sheriff420's Avatar
Sheriff420
46RE (a518) is the one with problems.
