Couple questions on a boosted 5.9 Magnum build.
#32
It was out of a Chryler Reman 46RH that was in a truck that got totalled... So I just kinda had it laying around as a "good used" core
TCS will make you a nice furnace brazed 2000 stall unit with their "better" lock-up clutch material for about $200 though.
Oh, guess I should say, while I`m here, that I got the engine/trans out and will be mounting the Magnum up today
#33
Gaping hole.
Trans tunnel
Drive shaft tunnel
Shiny
REAR axle
Drive shaft rear view
Drive shaft side view
Engine mount
Trans cross member
Pan(s) hang down a lil...
Rear leaf spring mount
Front leaf spring mount
View of how I tied the rear cross brace (for the rear mounts) together
Fuel cell, complete with fill neck and fuel pump module from car...
I'd post up some underhood pics, but it's pretty ugly under there yet... I'm still working on getting everything cleaned up under there (wires everywhere). I'll have plenty of time to do so too; I have to come up with $100 for a Cam Position Sensor and a Crank Position Sensor. I knew this thing was gonna nickel and dime me to death, but sheesh, this is ridiculous!
Trans tunnel
Drive shaft tunnel
Shiny
REAR axle
Engine mount
Trans cross member
#34
Well, I had some issues getting it hitting on all 8 (junkyard had given me a PCM from a 3.9 V6), but it LIVES!
http://www.youtube.com/watch?v=yi0An09-skE
#35
#38
Not yet, I need to finish hooking up the rear brakes, and jack the rear off the ground to run the trans through the gears with no load before I try moving the car under it's own power... That and I need to at the very least get the front half of the exhaust done to install the O2 sensor (it's open headers right now).
