removing U-joints
Old Feb 3, 2010 | 02:49 PM
mudxslinger's Avatar
mudxslinger
Default removing U-joints
im replacing my u joints on my front drive shaft (4x4) and i can not get them to budge and i was wondering what the easiest way to get them out without a special tool
Old Feb 3, 2010 | 04:04 PM
aliasmax's Avatar
aliasmax
Remove the c clips from the the inside. Get a cheap socket a little smaller than the cups. Get a hammer. On a smooth flat hard surface. Pound them until they start to move. raise the axle shaft while supporting it and finish pounding out the u joint.
Old Feb 3, 2010 | 04:10 PM
dodgeboy1979's Avatar
dodgeboy1979
or use a vice with the socket pushing on the cup and a larger socket for the other cup to move into.
Old Feb 3, 2010 | 04:20 PM
95RAM360's Avatar
95RAM360
c-clamp could work as well
Old Feb 3, 2010 | 04:24 PM
dodgeboy1979
I've also used a ball joint press
Old Feb 3, 2010 | 06:47 PM
Sheriff420's Avatar
Sheriff420
i broke a c clamp and a big vise trying to get them out of my rear driveshaft so if they aren't budging then those probably won't work.
i say get an angle grinder and a cut off wheel and cut the u joint off, then popping the caps out with a hammer and socket will be easy.
Old Feb 3, 2010 | 06:53 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
use some heat possibly......their getting changed anyways
Old Feb 3, 2010 | 06:59 PM
fatchance82's Avatar
fatchance82
http://dodgeram.org/tech/repair/U_joint/repair.htm
May help a little bit.
Old Feb 4, 2010 | 09:16 AM
Sheriff420's Avatar
Sheriff420
just hack it off with a grinder.
this is my axle shaft u joint. when i changed my sisters drive shaft u joints, i cut off both ears of the u joint that go into the caps, then it didn't take a hard hit at all with the hammer and a socket to get the caps to pop out.
Old Mar 11, 2010 | 01:10 AM
yakkier's Avatar
yakkier
im using a ****in sawzaw.
