just did my plenum!
Nothing, just let it sit overnight before you tear into it. A cheap plastic tool from Autozone or wherever will disconnect it at the fuel rail along with a rag to soak up any spillage. wear eye protection anyway.
And disconnect the negative battery cable first , before you do anything else.
1. bleed the pressure from your feul rail. there is a beeder valve on the right side. it works just like a tire valve stem.
2. yes i bought all parts from hughes. it will recomend other parts when ur on the plenum page.
3. if there is oil in there its bad. i didnt know how much oil i had in mine till i pulled it off of my intake i had oil pooled in my intake when it was upside down on the bench and my plenum pan was nothing but oil.
hopefully all continues to go well with mine.
anybody doing it should just get a hanes manual or a chilton it will help out a lot. oh and you dont have to pull the spark plugs and wires like the book will tell you to.
A big +1 on the Haynes or Chilton manual. Or this https://dodgeforum.com/forum/2nd-gen...e-ram-faq.html
The only that concerned me was when I read this in the repair manual: "(7) Perform the Fuel System Pressure release procedure
(Refer to 14 - FUEL SYSTEM/FUEL DELIVERY
- STANDARD PROCEDURE). Disconnect the
fuel lines (Refer to 14 - FUEL SYSTEM/FUEL
DELIVERY/QUICK CONNECT FITTING - STANDARD
PROCEDURE)."
PROCEDURE)."
-Matt
