Estimate Cost
Old Feb 8, 2010 | 07:45 PM
yingchu777's Avatar
yingchu777
Default Estimate Cost
Hello All,
How much money should I expect to pay for an estimate on whats causing 1 inch play in steering wheel? Thank you.
Old Feb 8, 2010 | 07:47 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Why not diagnose the problem yourself?
Old Feb 8, 2010 | 07:57 PM
PurplDodge's Avatar
PurplDodge
Well, what part has that much play in it? Thats a lot of play!
Old Feb 8, 2010 | 08:09 PM
dhvaughan's Avatar
dhvaughan
repair estimates that don't require shop time should be free. short test drives and "lets put it up on the rack and see whats wrong" are free.
play in the steering can be caused by a number of problems including steering box, idler arm, linkage, tie rod ends, track bar, ball joints, steering shaft, and some of the pieces and parts on the steering shaft.. pretty much any moving part.
i removed about 2 or 3 or 4 inches of rotational play from my steering by tightening up the box. i got lucky and avoided buying a new box, at least for the past 3 years. mine was almost undriveable.
1. Steering box adjustment
https://dodgeforum.com/m_657750/tm.htm
https://dodgeforum.com/m_899062/tm.htm
Old Feb 8, 2010 | 08:28 PM
redheadhunter21's Avatar
redheadhunter21
$0 for an estimate in Florida its a law that you recieve a free estimate before any mechanical work is done
zman17's Avatar
zman17
I don't know,I just want an estimate.
Old Feb 8, 2010 | 08:30 PM
J415's Avatar
J415
Over here in Nor Cal, I pay $100 when I need it to get diagnosed. That is if it's something I can't figure out. It's about an hours shop time.
Old Feb 8, 2010 | 09:17 PM
yingchu777's Avatar
yingchu777
Turning right and left there is almost 1 inch play in the wheel.
Old Feb 8, 2010 | 09:18 PM
yingchu777's Avatar
yingchu777
I want someone trained to fix it to do the job.
Old Feb 8, 2010 | 09:21 PM
yingchu777's Avatar
yingchu777
Thanks.
Made an appointment with a repair shop but do not feel comfortable bringing it to him, he said it sounds like a complex problem.
Quess I'll bring it back to dealer and have a list of issues you mention to check out.
