Short Box single cab 7" lift
Old Feb 9, 2010 | 01:38 AM
Gnarkill666's Avatar
Gnarkill666
Default Short Box single cab 7" lift
this is for anyone with a single cab short bed lifted around 7", do you have a CV joint on your rear driveline and if not do you get a weird noise at any speed (most likely higher speeds) you cant figure out, or that you know is cause from a driveline angle? was told its a harmonic imbalance because my rear axle is tilted up and all the angle from the lift is put on the upper part of the driveline where it slips onto the Xfer case, causing crazy noises in the pumpkin and Xfer case.
Old Feb 9, 2010 | 08:12 AM
olyelr's Avatar
olyelr
You sure its from your rear shaft? 7" of lift (well, actually probably only 5 or 6 in the back) should not cause any vibration issues if the rear axle is properly shimmed.
Did your transfer case get clocked when that lift was installed?
Old Feb 10, 2010 | 05:06 PM
Gnarkill666
Yeah its clocked but that only affects the front driveline.
Old Feb 10, 2010 | 10:49 PM
olyelr's Avatar
olyelr
Yep, I'm well aware of that. I was just wondering if it was at all possible that the noise was coming form the front shaft.
I dono man, my guess is its not the fault of the drive shaft angle. Theres just too many rams out there running around with that much lift or more without any issues. If the angle was too steep for the stock drive shaft to operate properly I'm sure skyjacker would offer a new drive shaft with the kit, or at least say a new one is recommended due to possible vibrations/noises.
Are you for sure the noise is coming from the rear? Maybe its in the rear diff? Or a bad u-joint (although I'm sure you checked those already)?
On a side note, how do you like that lift kit?
Old Feb 11, 2010 | 04:18 AM
Gnarkill666
Theres less then 8k miles on the lift, Heavy duty trany rebuild, ring & pinion, and the Xfer case was just rebuilt. had it all checked out muitiple times by the people that did all the work, and ive been into all of it myself. I did leave out one thing in the first post but it is only happening when i let off the gas. only thing left to do i should have tried when i was putting the Xfer case back in i guess, drop the driveline and see if it does it in front wheel drive or with no load at all.
Old Feb 11, 2010 | 01:31 PM
Aubrey's Avatar
Aubrey
I'm guessing you also have the transmission drop bracket installed.
Also, -On models with a rear carrier bearing, if a driveshaft vibration is present, the crossmember must be lowered to eliminate vibration.
So with that said, I'm thinking that that much lift on a single shaft with regular cab short bed may have some issues.
Old Feb 12, 2010 | 12:06 AM
olyelr's Avatar
olyelr
Transmission drop bracket? I have never heard of one for our truck. How would it even work without lowering the motor and transfer case too?
Short box regular cabs don't have a carrier bearing.
Knarkill, if you pull the rear shaft and take her for a test drive, don't forget to plug the rear output as you will loose some fluids.
Old Feb 12, 2010 | 09:56 AM
Aubrey's Avatar
Aubrey
Oly - it's in the installation instructions. There's a LOT of parts to a Skyjacker 7" lift.
Old Feb 12, 2010 | 01:22 PM
olyelr's Avatar
olyelr
Gotcha. I will have to check them out. I know the transfer case gets rotated, but I did not know about the transmission. Makes me curious.
Yeah, the kit definitely has a lot of parts... hence the reason for such a large price tag hahaha.
Old Feb 15, 2010 | 09:15 PM
acarlsson918778's Avatar
acarlsson918778
Any luck with that drivetrain yet? I'm new to the forum and I've been looking at the Skyjacker 7" long-arm kit for my '99 short bed regular cab ram. How does it perform?
