One big ram (wish it was mine)
Old Feb 11, 2010 | 02:09 PM
  #31
95MaroonMonster's Avatar
95MaroonMonster
wow, retard much
i like lifted trucks sure, look at mine, but there's a point where it's just stoopid...
...and that point is about anything over 6 inches, can't use it then
Old Feb 11, 2010 | 03:46 PM
  #32
redheadhunter21's Avatar
redheadhunter21
If the truck started out on a 3500 frame and had 2 1/2 ton rockwells under and a cummings motor it might be worth it, it would also be able to go off the road and not fall flat on its ***.
Look at the dinky axles still sitting underit, ok for 35's but not for the chunks of rubber on it.
Another idiot with no knowledge and to much money. Now he figured out that he is an idiot and wants to get rid of it
Old Feb 11, 2010 | 03:53 PM
  #33
yakkier's Avatar
yakkier
burn the evidence...
Old Feb 11, 2010 | 04:08 PM
  #34
95RAM360's Avatar
95RAM360
Originally Posted by Miami_Son
44s on 1500 axles and no mention of the gear ratios. If you don't snap the axle on a pothole, it probably takes a half block just to get to 30mph. So many red flags on that truck. Pass.
thats exacally what i looked for first. it says nothing about gears, its probably a hog
Old Feb 11, 2010 | 04:30 PM
  #35
PurplDodge's Avatar
PurplDodge
Originally Posted by 97ramnj
coolest part of the WHOLE truck is either the front triple shocks or the twin hood scoop thats it lol
Not to mention the twin sets of Fog Lights!
Some dumbass bid $15,000 on this piece of ****.
Old Feb 11, 2010 | 04:48 PM
  #36
harby's Avatar
harby
Thumbs down
It also doesn't say whether it's 4x4 or 2WD, although at first glance it looks like it is 4x4 due to the differential on the front axle, unfortunately there appears to be no prop shaft!!!
It also leans toward the driver side, not bad considering it seems to be sitting on level ground, lol!
Old Feb 11, 2010 | 05:05 PM
  #37
Miami_Son's Avatar
Miami_Son
Good catch there, Brit. Yep, no front driveshaft and you'd think that since he made the lift custom, he could have designed it without the Dodge lean in it.
Old Feb 11, 2010 | 06:26 PM
  #38
PurplDodge's Avatar
PurplDodge
Originally Posted by PurplDodge
My question to the seller:
His response:
"Unfortunately, I am sorry but they are no longer available. What is listed and in veiw in the pictures is hoe the truck comes."
My next question:
"Ok, I have a couple of other questions. What motor is in the truck? Is the front driveshaft still connected so you have 4WD? What axles are under the truck. And what gears do the axles have?"
I am awaiting his response!
Old Feb 11, 2010 | 07:12 PM
  #39
PurplDodge's Avatar
PurplDodge
His response:
My next question:
His response:
"I't has a 4.7 l V8. I don't know about the axel or gears I apologize. No the front drive axel is not connected it would require a custo fabricated shaft as we used it for a show truck we didn't need the 4x4. It does work just needs the part."
To the bidder of Dodge Ram V.I.N 3B7HF13Y5EG194859, ebay number 250575663766, do not buy this truck. It is obviously a POS and the owner/seller is a complete idiot (Wait, the driveshaft is missing; in-complete idiot).
Old Feb 11, 2010 | 07:29 PM
  #40
Miami_Son's Avatar
Miami_Son
4.7L V8? What a moron.
