Questions about body work and stuff
Old Feb 10, 2010 | 05:38 PM
ebk142's Avatar
ebk142
Default Questions about body work and stuff
whats up forum, Recently acquired a 95 Ram, Reg cab 1500 5.9, in need of body work, and hella rusty lol. Got some q's for you guys, but ill post them in the sections they need to be in rather then here.
Old Feb 10, 2010 | 05:41 PM
JackJ's Avatar
JackJ
This would be the forum to post them in. Welcome!
Old Feb 10, 2010 | 05:43 PM
ebk142's Avatar
ebk142
lol i know, but rather than my intro, thanks!
Old Feb 10, 2010 | 05:44 PM
95RAM360's Avatar
95RAM360
just ask your questions here since you've already made a thread
Old Feb 10, 2010 | 05:45 PM
PurplDodge's Avatar
PurplDodge
Dont start a new thread for your questions, just post them here in this thread.
Welcome to Dodge Forum.
Old Feb 10, 2010 | 05:50 PM
ebk142's Avatar
ebk142
well first off i got a ton of body work that needs to be done, i got the truck cheap because there was a worn out bearing in the transfer case, so I had my mechanic fix that, and now to the body work. I can get some pics in the morning, if you wanna see what im talking about, but its dinged and scratched all over. Its black so every little thing shows. I'd like to have it repainted in the spring, but do the body work myself. then move on to lift kits, exhaust systems, tires. etc... any recommendations ?
Old Feb 10, 2010 | 05:57 PM
95RAM360's Avatar
95RAM360
do the plenum gasket first
Old Feb 10, 2010 | 05:59 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Wrong order of attack , lift kits and tires are last(not to mention gearing) but the first thing to do is fix the plenum,replace o2's and the cat. Then move on to the OEM suspension/steering/drivetrain, exhaust,body work. JMO
Old Feb 10, 2010 | 06:02 PM
zje400ex's Avatar
zje400ex
For a lift kit it all depends how big you wanna go. Here are the lift sizes and tires that will fit the lift without rubbing
Stock height - 31x10.50's (265's)
2" level - 33x11.50's (285's)
3" lift - 33x12.50's (305's)
5" lift - 35x12.50's (315's)
If you go 5" you should probably regear your axles because the truck will be a dog. Lots of people like flowmaster mufflers and the magnaflow high flow cats for their exhaust systems. For tires it's whatever kind of driving you do. If you're using it for road use only just get some a/t's but if you plan on going offroad a lot go with some m/t tires.
Old Feb 10, 2010 | 06:03 PM
PurplDodge's Avatar
PurplDodge
Yeah, do common tune up stuff before you do anything else.
