My First Ram, Tranny Problem
Old Feb 10, 2010 | 09:45 PM
latinowarrior's Avatar
latinowarrior
Thumbs down My First Ram, Tranny Problem
I just bought a 2001 Ram 1500 4X4 with 115,000 miles, Auto tranny with a 5.2 L engine. The automatic transmission shifts very smooth thru all forward gears BUT DOESN'T HAVE REVERSE and the 4x4 WHEEL DRIVE WORKS GREAT. Whats the problem? I need help and hoping it's not that expensive to repair, I just spent $3,500 on it.
Old Feb 10, 2010 | 10:00 PM
Gerehead8's Avatar
Gerehead8
Try adjusting the low/reverse aka rear band.
Old Feb 10, 2010 | 10:09 PM
Ram_Me's Avatar
Ram_Me
Don't adjust it yourself if you haven't done so before. Just get your Transmission serviced instead.
Also, check this out:
https://dodgeforum.com/forum/2nd-gen...diagnosis.html
Old Feb 10, 2010 | 10:18 PM
Gerehead8's Avatar
Gerehead8
I have seen multiple people warning people to not adjust the tranny bands themselves. Is there a horror story to this or what? It is really easy so I'm just curious.
To the O.P. if you don't have automotive experince get it serviced it should be cheap. Have them adjust both bands and change the fluid and filter.
Old Feb 10, 2010 | 10:25 PM
Ram_Me's Avatar
Ram_Me
Someone on this forum who shall not be named (PurplDodge) adjusted his bands and killed his transmission. There might have been some others too.
Old Feb 10, 2010 | 10:35 PM
Gerehead8's Avatar
Gerehead8
Alright thanks I figured something like that happend.
Old Feb 10, 2010 | 10:38 PM
sit22 II's Avatar
sit22 II
did anyone tryed the recall there is for the reverse gear ??
Old Feb 10, 2010 | 10:41 PM
95RAM360's Avatar
95RAM360
^ english please
try what recall on reverse gear? i have seen no recalls to a reverse gear, and ive tried searching or recalls many times
Old Feb 10, 2010 | 11:34 PM
master tech's Avatar
master tech
Site Moderator & Tech
Remove the transmission pan and inspect the rear lever, see if the strut is laying in the pan. Also ck the reverse piston. Its common for the piston to break in half. Or the snap ring to pop out of the groove.There was a recall for the 1989 thru 1992 dakota trucks for a reverse spool valve, and then there was a TSB to replace the spool valve for a reverse buzz on the ram trucks.
Old Feb 10, 2010 | 11:37 PM
PurplDodge's Avatar
PurplDodge
The reason it happened to me was because I used a Harbor Freight torque wrench. If you DIY I suggest spending some money on a really good torque wrench.
