4x4 shifter conversion
Old Feb 11, 2010 | 03:01 PM
yakkier's Avatar
yakkier
i wouldnt think you couldnt do it, hell basicly should be the same process as putting in a short shifter for a manual tranny
Old Feb 11, 2010 | 03:07 PM
Miami_Son's Avatar
Miami_Son
Originally Posted by offroadjosh
Well I dont want to replace my t-case just to change the shifter. I was just wondering if anyone knew if I could just change the linkage.
Josh
I'd like to know what the point of this swap would be?
Old Feb 11, 2010 | 03:17 PM
99DRAM31887's Avatar
99DRAM31887
i wasn't talking about switchin out your t-case but finding the shifter and linkage from a 98+ with the same t-case as your 96
Old Feb 11, 2010 | 03:44 PM
offroadjosh's Avatar
offroadjosh
The point of the swap is I like the shift process A LOT better. Its way smoother. Mine is a bit*h sometimes and I think a straight shift would work better.
Josh
Old Feb 11, 2010 | 04:13 PM
PurplDodge's Avatar
PurplDodge
Josh
The straight shift can be a PITA at times. You really have to throw the shifter to get the t-case to engage into low range. You really never know if it is engaged until you hit the throttle. This scared me when I was trying to get up my snow-covered driveway the other day. Popped from 4-low to neutral.
Maybe you could e-mail or call Magna (They own New Venture Gear) and see if they know. You could also go to a transmission or off-road shop and ask them. Sometimes Although I doubt the internals are the same, it may be worth the try.
http://www.magna.com/magna/en/contact/
If you do decide to change out your transfer case, make sure you get a 231HD case instead of the standard 231D case.
Old Feb 11, 2010 | 04:15 PM
Miami_Son's Avatar
Miami_Son
Well, if there's a down and to the right requirement of your transfer case to get it into any gear, then that is usually an internal thing. I doubt you could swap shifter mechanisms and have it work properly.
Old Feb 11, 2010 | 05:21 PM
BIGRED97's Avatar
BIGRED97
looking at the spare transfer case/transmission (out of a 95) i have in my back yard, it doesnt look possible. the shifter goes straight into the top of the case, there isnt any linkage but internal. thats probably why its so hard because there is no hydraulic support or linkage to make it smooth, its that handle mashing into gears. im not sure if the 98+ are a linkage type or not, but i would assume so, they are alot smoother, and easier to shift into.
