I have a hunch on why I get such bad MPG
Old Feb 15, 2010 | 01:46 AM
  #51
redheadhunter21's Avatar
redheadhunter21
If the tune up doesnt help with the mpgs, I would look into a high flow cat or gutting the cat you have, if the cat is going bad it will hurt mpgs
Old Feb 15, 2010 | 01:51 AM
  #52
Laramie1997's Avatar
Laramie1997
The smallest tire that Dodge put on these rams was a 245/75-16....
Old Feb 15, 2010 | 01:54 AM
  #53
2001Ram's Avatar
2001Ram
The one inbetween the 2 02 sensors? I gotta cut it off and weld it back on correct?
Old Feb 15, 2010 | 02:06 AM
  #54
redheadhunter21
Yeah the catalytic converter(cat) is the one between the 02 sensors and some people cut them off and take a bar and knock all the insides out and weld it back in or clamp it, if you have emissions you will need to put a cat back in
Also when gutting cat you are at a chance of getting a cel there are a couple tricks to fixing this main way to do this is non-fouler trick
Old Feb 15, 2010 | 02:14 AM
  #55
intense00's Avatar
intense00
I guess the tire calc has some bad info.
at a 245 stock size, with 265's
Speedometer Difference: 5.844% too slow
http://www.1010tires.com/TireSizeCal...?action=submit
Old Feb 15, 2010 | 02:22 AM
  #56
Bubba39047's Avatar
Bubba39047
i know its off the topic, but do you idle at 650 rpm?
Old Feb 15, 2010 | 03:08 AM
  #57
2001Ram's Avatar
2001Ram
Yup. why?
Old Feb 15, 2010 | 09:15 AM
  #58
pcfixerpro's Avatar
pcfixerpro
I am pretty sure the other guy posting in here is correct that 225/75/16's were used on some 2wd's which would make them the smalllest. Let me look around and ill get back to ya.
Edit
The FSM does list a goodyear tire that was offered in this size. Tire rack lists the 225 & 245 sizes. My truck came with 245's stock and listed 265's as option (which I had installed last summer). To clear any confusion, OP would you mind snapping a clear pic of the sticker in your driver door and posting back? Thanks
Old Feb 15, 2010 | 10:16 AM
  #59
zman17's Avatar
zman17
Retired Moderator - RIP
My silver truck originally had 225's on it.
Old Feb 15, 2010 | 10:24 AM
  #60
Gerehead8's Avatar
Gerehead8
My door jam sticker lists 225/75/R16's as my stock size. Wether it left the dealer lot with these on I have no idea. Mines a 4x4 too.
