2WD lift questions
Old Feb 23, 2010 | 11:27 AM
  #41
DODGEPWR's Avatar
DODGEPWR
Originally Posted by Dixie Mudslinger
block lifts just lift the bed/cab up leaving the chassis at the stock height so you will have to move your bumpers if you use blocks. it wouldnt change your shock travel
umm i wasnt tlking about a body lift..Which is obviously what your talking about. I said lift blocks...As in Lift blocks under the leafs. I found my answer anyway. I found out it will be fine because the 4x4 ram uses the same rear shocks as the 2wd..Thus i can lift it in the rear as much as the stock 4x4 without changing the shocks.
EDIT: AWW CRAP. Dakotas ram beat me to it!
Old Feb 23, 2010 | 11:28 AM
  #42
Dixie Mudslinger's Avatar
Dixie Mudslinger
ah ok :P didnt know those existed learn something new everyday ^^
Old Feb 23, 2010 | 11:44 AM
  #43
yakkier's Avatar
yakkier
pointless lol
Old Feb 23, 2010 | 11:57 AM
  #44
Weldor's Avatar
Weldor
Old Feb 23, 2010 | 11:58 AM
  #45
dakotas ram's Avatar
dakotas ram
then stay out of the thread if you have nothing to contribute but negative comments....hes not asking for opinions
Old Feb 23, 2010 | 12:05 PM
  #46
Weldor's Avatar
Weldor
Ditto isn't a negative comment, you called us haters...that is. Take your own advice.
Old Feb 23, 2010 | 01:05 PM
  #47
RealReggaerider's Avatar
RealReggaerider
Guyz guyz come on this is to inform and show your stuff....be cool ! i just wanted info on 2wd lift on 33`s ...Be cool .....
Old Feb 23, 2010 | 01:43 PM
  #48
redheadhunter21's Avatar
redheadhunter21
And you can gain something out of lifting a 2wd I need ground clearance for work but dont need a 4x4 or the extra weight, only reason I havent lifted is I can drive around were I cant go
Old Feb 23, 2010 | 04:23 PM
  #49
01greenram's Avatar
01greenram
everyone gets a 4x4 and lifts it but you dont see alot of lifted 2wd thats why i did mine just dont want to be like everyone else even if its pointless
Old Feb 23, 2010 | 06:01 PM
  #50
Weldor's Avatar
Weldor
Theres a reason why you see alot of 4x4's that are lifted and not alot of 2wd's. But to each his own, I'm not trying to bash you or your rig.
