Strange noise in 4WD
Old Feb 16, 2010 | 11:16 PM
ridin-high2001's Avatar
ridin-high2001
Default Strange noise in 4WD
2nd gen 4x4 having trouble with the 4 wheel drive. engages and works fine but while making a turn while in 4 wheel drive i get a popping noise. took it to a 4 wheel drive center and they said it was the transfer case and that the chain was loose. any input?
Old Feb 17, 2010 | 07:46 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second generation Ram section,
FF
Old Feb 17, 2010 | 08:14 AM
silverbullet-dodgeram's Avatar
if it only does it in 4wd i wouldnt worry. mine does it to, it just means your wheels are securely locked in to 4wd.
Old Feb 17, 2010 | 08:41 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Sounds like ujoints to me.
Old Feb 17, 2010 | 08:48 AM
Pacmanloads's Avatar
Pacmanloads
I have the same problem........ u joints are all fine on mine. I do have a small leak on my transfer case. Is there a transfer case that anyone recommends for a 95 ram as if i have to take it off anyways and repair it I would rather put a new one on that won't explode when I am in the woods. Thanks
Old Feb 17, 2010 | 09:22 AM
ridin-high2001
i just put new u joints less than a year ago to try to fix it but no luck. i dont wanna put a new transfer case in if it is something minor
Old Feb 17, 2010 | 09:56 AM
pcfixerpro's Avatar
pcfixerpro
I think we are entitled to a little more information then that. How about pinpointing the general are of the poping sound? transfer case and u-joint are pretty far apart so distinguishing noise shouldn't an issue so roll down your window. Also under what terrain are you turning in 4wd.
Old Feb 17, 2010 | 10:20 AM
Miami_Son's Avatar
Miami_Son
Is this an attempt at humor? Odd noises should never be ignored as they can be an indicator of impending breakage.
Old Feb 17, 2010 | 10:34 AM
95RAM360's Avatar
95RAM360
I have the HD model in mine, its got 199920 miles on it, and ive heard these are pretty much bulletproof
Old Feb 17, 2010 | 09:02 PM
ridin-high2001
i was in mud with snow on top and i cant really tell where its coming from and it feels like the more i turn the louder it gets.
