Making my own plenum plate
Old Mar 3, 2010 | 06:08 PM
  #171
PurplDodge's Avatar
PurplDodge
Originally Posted by Cheek-oh!
actually the hughes is a hundred and change...... so... he's saving 40 and change....
So, shipping is around $20 for the Hughes? Now that is outrageous!!! I'm acually saving $80 over that price.
Old Mar 3, 2010 | 06:49 PM
  #172
1fast2liter's Avatar
1fast2liter
isnt the hughes one dimpled for the gasket?
Old Mar 3, 2010 | 07:06 PM
  #173
Cheat's Avatar
Cheat
It might but there using that metal compression stuff, Not a felpro.
Old Mar 3, 2010 | 09:06 PM
  #174
lblair04's Avatar
lblair04
Hughes's plate isnt dimpled. Mine was around $140 or something, with gaskets and TTY bolts (which are needed). Spending the extra was well worth it for me, to give me more time with the wife and lil man. But good job purpl, hope it works for ya. Did you decide to use TTY bolts, since they are needed?
Old Mar 3, 2010 | 09:15 PM
  #175
Cheek-oh!'s Avatar
Cheek-oh!
hughes isn't dimpled.... its just a piece of flat aluminum stock.... i paid 104 for the plate, gasket, and bolts.
Old Mar 3, 2010 | 09:24 PM
  #176
PurplDodge's Avatar
PurplDodge
I might use the TTY bolts. Someone told me that they got bolts from their dealer for $12. Hell, I might get the gaskets there if the prices are right.
Old Mar 3, 2010 | 09:59 PM
  #177
jamesnb's Avatar
jamesnb
I reused the plenum bolts. I used new intake bolts for $1.50/bolt at the dealership.
Old Mar 4, 2010 | 11:20 AM
  #178
J415's Avatar
J415
I bought some TTY bolts from the stealership about 4 years ago and they were just about $15. I hope they still are.
Old Mar 4, 2010 | 03:21 PM
  #179
lblair04's Avatar
lblair04
I was reading up on tty vs grade 8, and pretty much all I could figure out is that the bolts are supposed to stretch, and kind of act like a spring to keep everything tight. As far as using the grade 8, they dont stretch the same amount. Can someone clarify that Im reading it correctly? I figured I would try to do some research since I wasnt sure exactly the reasoning why to use TTY instead of grade 8, but know there is a reason somewhere in the specs of bolts.
Thanks
Old Mar 4, 2010 | 07:09 PM
  #180
WaynesWorld's Avatar
WaynesWorld
wtg purp! Mad fab skills
