2" true duals?
Old Feb 18, 2010 | 11:19 AM
ironman888's Avatar
ironman888
Default 2" true duals?
should i go with 2" true dual exhaust with 2" high flow magnaflow cats or should i go with bigger pipe for sound etc.
I think 2" should be sufficient i just want to here other opinions
Old Feb 18, 2010 | 11:31 AM
vmann's Avatar
vmann
i'd leave it at 2
Old Feb 18, 2010 | 11:48 AM
Aubrey's Avatar
Aubrey
I'd say 2" for duals as well. Most of the single kits are 2 1/4 or maybe 2 1/2.
Old Feb 18, 2010 | 12:03 PM
blackskyracing's Avatar
blackskyracing
I am going to assume you need to pass inspection as the reason for bothering with cats.
That being said, you could do a couple of step-ups. IE 2" into an x-pipe near the stock cat location then to the back of the cab, 2 1/4 to the axle, then 2 1/2 over the axle to the back, and possibly some tips... I`ve done a couple that way and they sound great, completely unique, you get a deep throaty rap when you stand on it and it just seems to snarl while cruising in town. Granted there were no mufflers involved. I wish I knew where one of those trucks ended up, the owners have all sold them and I don`t have any video or even sound clips
EDIT: Forgot to mention a 45* exit on the pipes with the leading edge of the pipe sticking out slightly farther than the rest will help to scavenge the exhaust out of the bigger pipes...
Old Feb 18, 2010 | 02:56 PM
ironman888's Avatar
ironman888
Thanks for the input guys
Old Feb 18, 2010 | 03:48 PM
redheadhunter21's Avatar
redheadhunter21
The smallest I would do on pipe size would be 2 1/4 I am running 2 1/2 with no cat and it performs good couldnt imagine going back down to a 2
Old Feb 18, 2010 | 04:04 PM
blackskyracing
for a 250(ish) hp engine 2" is more than enough. Anything bigger than that for at least the first couple of feet will take away from low end torque...
Old Feb 18, 2010 | 08:37 PM
ironman888's Avatar
ironman888
any body know what i should expect to pay so i dont get ripped off. I cut the stock cat off so the pipes will start from where the cat was and go back and y out the back.
Old Feb 18, 2010 | 08:47 PM
Dixie Mudslinger's Avatar
Dixie Mudslinger
when i got a estimate for true duals with thrush turbo mufflers it was 200 with 2 1/4 pipe all the way without tips or cats at a local muffler shop but probably would vary with the company you use to run the exhaust
Old Feb 18, 2010 | 08:52 PM
silver06cummins's Avatar
silver06cummins
I just had the cat cut off my truck and 2 1/2 pipe into a 2 chamber flowmaster and a single tailpipe and its sounds awesome, to bad the transmission took a shiot and its sitting in the shop now LOL
